How to show something is a covector?
  • Thread starter Baggio
In summary, the conversation discusses the task of showing that (-x, -y, -z, t) and (df/dx, df/dy, df/dz, df/dt) are covectors. Two methods are suggested: applying a coordinate transformation and showing that they are linear functionals. The latter method is considered to be nicer. There is also a discussion about the difference between taking the scalar product and plugging a vector into a covector.
Baggio
211
Hi, think this question will be relatively simple for those familiar with tensor analysis
Need to show that (-x, -y, -z, t) is a covector. We're given a hint that we should apply a lorentz boost in the x direction but i don't see the point of this. If that is a covector then surely you can say
x
y
z
t
is a vector and just take the scalar product to find the interval?
There is also a samilar question where by I have to show that
(df/dx, df/dy,df/dz,df/dt) (f is a scalar field) is a covector
none of these questions are for credit or anything it's just to help with our understanding...but I don't :(
Thanks
Well, there are two methods.
(1) You could, as you said, apply a coordiante transformation, and make sure the components transform appropriately.
(2) You could show that they are (coordiante-independent!) linear functionals on the space of vectors.
Your hint was to apply method (1). It has the advantage of being a mindless, straightforward algorithm.
But method (2) is often nicer, as you suggest. You know that [itex]\mathbf{x} := [x, y, z, t]^T[/itex] is a vector, and left multiplying by [-x, -y, -z, t] is, as you say, the (coordinate independent!) function:
[tex]
f(\mathbf{y}) = \langle \mathbf{x}, \mathbf{y} \rangle
[/tex]
At least I think that's what you said -- I hope you didn't mean to simply take the product1 of [-x, -y, -z, t] and [itex][x, y, z, t]^T[/itex]: sure, the result is an invariant, but you need to show it's invariant no matter what vector you use on the right.
For the second problem, you know a suitable geometric interpretation of the gradient, and what you can do with the gradient and a vector.
1: This is not a scalar product! The scalar product, at least in mathspeak, is a function of two vectors. When you have a covector and a vector, you're just plugging the vector into the covector. (Since a covector is a linear functional) In the coordinate representation, it's multiplying a 1xN matrix by an Nx1 matrix.
FAQ: How to show something is a covector?
What is a covector?
A covector is a linear functional that maps a vector to a scalar value. It can also be thought of as a one-form or a dual vector.
How is a covector different from a vector?
A vector represents a physical quantity with both magnitude and direction, while a covector represents a linear transformation from vectors to scalars.
How do you show that something is a covector?
To show that something is a covector, we need to check if it satisfies two properties: linearity and duality. It should also be noted that covectors can be represented as column vectors, with each element representing a different basis vector.
What is the notation used to represent a covector?
A covector is usually represented using a lower case letter with a subscript index, such as αi. It can also be written as a row vector with angled brackets, such as <α₁, α₂, α₃> or as a function, such as α(x,y,z).
How is a covector used in physics and mathematics?
Covectors are used to describe quantities that are independent of the coordinate system, such as gradient, curl, and divergence. In physics, they are used to represent physical quantities such as electric and magnetic fields, while in mathematics, they are used in areas such as differential geometry and functional analysis.
