How to show that a trajectory is closed?
In summary, the conversation is about the conditions for a pendulum in a rotating reference frame to have a closed trajectory. The paper referenced discusses the condition for a closed trajectory and mentions the role of asymmetry in the system. There is also mention of the "trajectory fills an annulus" condition and a desire for further literature on the topic. It is noted that a closed trajectory is equivalent to periodic motion.
guest1234
41
Main question in the title.
I did a group work in analytic mechanics about pendulum in rotating reference frame and stumbled upon this one: http://peer.ccsd.cnrs.fr/docs/00/50/17/84/PDF/PEER_stage2_10.1016%252Fj.ijnonlinmec.2008.03.009.pdf. Does this always hold?
The trajectory is closed if and only if the motion is periodic.
In my solution, there are two coordinates with the same frequency (different amplitudes) but asymmetrical in general sense (diff equations that described system were asymmetrical). Will trajectory close regardless of asymmetry?
The "trajectory fills densely an annulus" condition (see next page) is quite enigmatic, too. The angular velocity of inertial reference frame must be in the same order of magnitude as eigenfrequency (hope it's right term for this) of rotating reference frame, otherwise period of precession is too small and trajectory fills a certain region on a plane of motion. I don't see any irrational numbers involved.
Also, I hope to see any references to literature that help to gain insight on questions like that.
edit: I guess that "trajectory fills an annulus" means the same as "trajectory is not closed", so it all boils down to that irrational number.
Motion is periodic <=> after some time t, the system returns to its initial state <=> trajectory is closed
They are equivalent, assuming the system itself is time-independent.
FAQ: How to show that a trajectory is closed?
How do you define a closed trajectory?
A closed trajectory is a path or curve that starts and ends at the same point, without any breaks or interruptions along the way. It forms a loop and can be repeated indefinitely without any change in direction or shape.
What are the conditions for a trajectory to be considered closed?
In order for a trajectory to be closed, it must satisfy two conditions: 1) the trajectory must be continuous, meaning there are no gaps or holes along the path, and 2) the trajectory must be periodic, meaning it repeats itself after a certain interval of time or distance.
How can you visually show that a trajectory is closed?
One way to visually demonstrate a closed trajectory is by plotting the path on a graph and observing that it forms a closed loop. Another way is by using a physical model, such as a pendulum or a planet orbiting around a star, and showing that it returns to its starting point after completing a cycle.
What mathematical tools can be used to prove that a trajectory is closed?
To prove that a trajectory is closed, mathematical tools such as differential equations, vector calculus, and complex analysis can be utilized. These tools can help analyze the behavior of the trajectory and show that it satisfies the conditions for being closed.
Can a trajectory be closed in some parts but open in others?
No, a trajectory is either closed or open in its entirety. It cannot be partially closed and partially open. However, a trajectory can have multiple closed sections connected by open sections, such as a figure eight shape, but the entire path must ultimately form a closed loop.
10K
