I How to show the diagonal in the extended plane is closed?
psie
TL;DR Summary
Consider ##\{(x,x):x\in\mathbb R\}##. I've managed to show this set is closed in ##\mathbb R^2## by showing its complement is open. Now using what I've already showed, how can I argue that ##\{(x,x):x\in\overline{\mathbb R}\}## is closed in ##\overline{\mathbb R}^2##?
Let ##(f_n)## be a sequence of measurable functions from ##E## into ##\mathbb R##. I'm reading a proof of the fact that the set ##A## of all ##x\in E## for which ##f_n(x)## converges in ##\mathbb R## as ##n\to\infty## is measurable. The proof goes like this (I'm paraphrasing):
Define ##G:E\to\overline{\mathbb R}^2## by ##G(x)=(\liminf f_n(x),\limsup f_n(x))##. Then ##G## is measurable and if ##D=\{(x,x):x\in\mathbb R\}##, then $$A=\{x\in E:-\infty<\liminf f_n(x)=\limsup f_n(x)<\infty\}=G^{-1}(D).$$So the measurability of ##A## follows since ##D## is measurable subset of ##\overline{\mathbb R}^2## (note that ##\{(x,x):x\in\overline{\mathbb R}\}## is measurable as a closed subset of ##\overline{\mathbb R}^2##).
Why is ##\{(x,x):x\in\overline{\mathbb R}\}## closed in ##\overline{\mathbb R}^2##? As I said, I can show the diagonal with ##x\in\mathbb R## is closed in ##\mathbb R^2##, but if ##x\in \overline{\mathbb R}## and the space is ##\overline{\mathbb R}^2##, how does one proceed?
psie said:
TL;DR Summary: Consider ##\{(x,x):x\in\mathbb R\}##. I've managed to show this set is closed in ##\mathbb R^2## by showing its complement is open. Now using what I've already showed, how can I argue that ##\{(x,x):x\in\overline{\mathbb R}\}## is closed in ##\overline{\mathbb R}^2##?
Is ##\overline{\mathbb R}## the 1-pt compactification? What metric do you use in ##\overline{\mathbb R}^2##; the product metric? Edit: Is ##\overline{\mathbb R}^2=\overline {\mathbb R} \times \overline {\mathbb R}##?
Edit 2: Isn't the compactification map an embedding , and, if so, it sends closed sets to closed sets.
Why does you proof for ##\mathbb R## doesn't work for ##\overline{\mathbb R}##? In any case for a topological space ##X##, the diagonal is closed in ##X\times X## (with the product topology) if and only if ##X## is Hausdorff. This is easy to check. And your ##\overline{\mathbb R}##, I suppose is Hausdorff.
Good questions.
Yes, ##\overline{\mathbb R}## is ##\{-\infty\}\cup \{\infty\}\cup \mathbb R##. The ad hoc metric is I think ##d(x,y)=|\arctan x-\arctan y|##, so it is homeomorphic to ##[-\pi/2,\pi/2]##. Yes, ##\overline{\mathbb R}^2=\overline {\mathbb R} \times \overline {\mathbb R}##.
I have only very rudimentary tools at my disposal (metric spaces and the fact that ##\overline {\mathbb R}## is metrizable), so I don't understand your Edit 2.
It doesn't work because the proof uses the Euclidean norm on ##\mathbb R^2##. We can't equip ##\overline {\mathbb R}^2## with the Euclidean norm. :frown:
You take something off the diagonal ##(x,y)##, this means ##x\not = y##. Then you take to open sets ##U## and ##V## that don't intersect and contain ##x## and ##y## respectively. Then ##U\times V## is an open set containing ##(x,y)## and not meeting the diagonal.
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
