How to Simplify an Integral Involving tan x
  • MHB
  • Thread starter Math1
  • Tags
    Tan
In summary, the integral $\displaystyle \int_{0}^{\pi/2} \frac{dx}{1+(tan(x))^{\sqrt2}}$ can be simplified by replacing $\sqrt2$ with any power and using the property that $\displaystyle \int_{0}^{\pi/2} \frac{\cos^{\alpha}(x)}{\sin^{\alpha}(x)+\cos^{\alpha}(x)}dx$ is equal to $\displaystyle \int_{0}^{\pi/2} \frac{\sin^{\alpha}(x)}{\sin^{\alpha}(x)+\cos^{\alpha}(x)}dx$. By adding these two equations and rearranging, the integral
Math1
Could anyone tell me how to start,
In a book ,it was given that $\sqrt2$ does not even matter
Replace $\sqrt2$ for any power and put $x\mapsto\dfrac\pi2-x.$
\( \displaystyle \begin{align*}
I &=\int_{0}^{\pi/2}\frac{1}{1+\tan^{\sqrt{2}}(x)}dx \\ \Rightarrow I &=\int_{0}^{\pi/2}\frac{\cos^{\sqrt{2}}(x)}{\sin^{\sqrt{2}}(x)+ \cos^{\sqrt{2}}(x)}dx \qquad (1)
\end{align*} \)
Applying Property,\( \displaystyle \begin{align*}
I &= \int_{0}^{\pi/2}\frac{\cos^{\sqrt{2}}\left( \frac{\pi}{2}-x \right)}{\sin^{\sqrt{2}}\left( \frac{\pi}{2}-x \right)+ \cos^{\sqrt{2}}\left( \frac{\pi}{2}-x \right)}dx\\ \Rightarrow I &= \int_{0}^{\pi/2}\frac{\sin^{\sqrt{2}}(x)}{\sin^{\sqrt{2}}(x)+ \cos^{\sqrt{2}}(x)}dx \qquad (2)
\end{align*} \)
Add equations (1) and (2) and see what happens! (Giggle)
Let $x = \tan^{-1}{t}$, then:
$\begin{aligned} I & = \int_{0}^{\pi/2}\frac{1}{1+\tan^{\alpha}{x}}\;{dx} \\& = \int_{0}^{\infty}\frac{1}{(1+t^2)(1+t^{\alpha})}\;{dt} \end{aligned}$
Range it from $[0, 1]$ and $[1, \infty]$,
$\displaystyle I = \int_{0}^{1}\frac{1}{(1+t^2)(1+t^{\alpha})}\;{dt}+\int_{1}^{\infty}\frac{1}{(1+t^2)(1+t^{\alpha})}\;{dt}$
Put $t \mapsto \frac{1}{t}$ for the second one,
$\displaystyle \begin{aligned}I & = \int_{0}^{1}\frac{1}{(1+t^2)(1+t^{\alpha})}\;{dt}+\int_{0}^{1}\frac{t^{\alpha}}{(1+t^2(1+t^{\alpha})}\;{dt} \\& = \int_{0}^{1}\frac{1+t^{\alpha}}{(1+t^2)(1+t^{ \alpha})}\;{dt} = \int_{0}^{1}\frac{1}{1+t^2}\;{dt} = \frac{\pi}{4}.\end{aligned}$
FAQ: How to Simplify an Integral Involving tan x
What is the definition of an integral?
The integral is a mathematical concept that represents the area under a curve in a graph. It is used to calculate the total accumulation of a quantity over a given interval.
What is the difference between definite and indefinite integrals?
A definite integral has specific limits of integration and gives a single numerical value as the result. An indefinite integral does not have limits of integration and gives a function as the result.
What is the relationship between integration and differentiation?
Integration and differentiation are inverse operations. Integration is the reverse process of differentiation, and vice versa. This means that the integral of a function is the anti-derivative of that function.
How do you integrate a function with trigonometric functions?
To integrate a function with trigonometric functions, you can use trigonometric identities to simplify the expression and then use techniques such as substitution or integration by parts.
What is the significance of the constant of integration in an indefinite integral?
The constant of integration is a constant term that appears when finding the indefinite integral of a function. It represents the family of functions that have the same derivative, as derivatives of constants are always zero.
