How to simplify cube root expression
In summary, the student attempted to solve the cubic equation by cubing and using the Difference of Cubes formula, but got stuck. They then found that a=1 and b=1 worked to give a solution.
Daniel McKinley
Solving the cubic equation x^3 + 6x = 20 by using formula gives
(10+ sqrt(108))^1/3 - (-10 + sqrt(108))^1/3
How do you show that this comes out exactly 2? No calculators allowed.
Tried cubing the expression and tried using the Difference of Cubes formula.
You can plug in for x (a - b) and get (a - b)^3 + 6(a-b) = 20. Expand out to get (a^3 - 3(a^2)b + 3a(b^2) - b^3) + 6a - 6b = 20. Were you able to get that far? Where did you get stuck? I'm not familiar off-hand with Diff of cubes. I will look that one up.
Daniel McKinley said:
(10+ sqrt(108))^1/3 - (-10 + sqrt(108))^1/3 = 2
If the result is that simple, there must be a trick:) Try to find the numbers a and b so as (a+b)3=10+√108 and (a-b)3=-10+√108.
Hint : first factorize 108.
Likes scottdave
you say you've tried but haven't showed what you have tried.
Firstly by substituting x = 2 in your equation you see that it is a solution. So (x - 2) is a factor of the cubic, so dividing by this term gives you a quadratic from which you can get the other roots.
However your question was just arithmetic.
√(108) ? 108 has a lot of factors so you can express √108 more naturally in terms of smaller numbers.
For the rest, I tried two avenues that both seem to be working, because seeming to be giving lots of simplifications, but in the end they didn't work. I might be onto something else but maybe tomorrow if no one else gets it first.
Okay I think this is it.
Our expression reduces to
(10 + 6√3) - (-10 + 6√3)
You hope that each of the two terms are perfect cubes. Maybe you can show they have to be. Maybe they have to be for this to give you an exact integer at the end.
Perfect cubes of something involving √3
Now (a + b√3)3 = a3 + 3a2b√3 + 9ab2 + 3b3√b
So we have two conditions to satisfy
For the non-surd term a3 + 9ab2 = 10
And the first thing you try:
a = 1, b = 1 works!
I will leave you to complete this now, and to worry about whether this will always work later.
However I think this has all been probably unnecessary.
That you may be doing this at the wrong stage in the cubic solution or some other confusion.
In the cubic solution you do get the difference between two cubes
X3 - Y3 = 0
where X, Y are linear in the unknown, or Y is a constant.
Then you can use the difference between two cubes formula - but it is obvious anyway - to get one solution X = Y .
When you have worked out something please COME BACK and tell us about the problem and solution because I hate doing this amount and then a problem is left hanging and Incompleted And I hate the student who does it!
(PS Well now I see you are a teacher not a student so you should understand this.)
Related to How to simplify cube root expression
1. What is a cube root expression?
A cube root expression is a mathematical expression that involves finding the number that, when multiplied by itself three times, gives the original number. It is represented by the symbol ∛ or "cube root". For example, the cube root of 27 is 3, since 3 x 3 x 3 = 27.
2. How do I simplify a cube root expression?
To simplify a cube root expression, you need to find the perfect cubes (numbers that can be multiplied by themselves three times) within the expression and take them out of the cube root. Then, you can simplify the remaining numbers outside the cube root using basic algebra rules.
3. What is the difference between simplifying and evaluating a cube root expression?
Simplifying a cube root expression involves making it easier to work with by removing perfect cubes and simplifying the remaining numbers. Evaluating a cube root expression involves finding the numerical value of the expression by plugging in values for the variables, if any, and solving the resulting equation.
4. What are some common mistakes to avoid when simplifying cube root expressions?
Some common mistakes to avoid when simplifying cube root expressions include not recognizing perfect cubes, forgetting to take out common factors, and making calculation errors. It is important to double check your work and simplify as much as possible to avoid these mistakes.
5. Can I use a calculator to simplify cube root expressions?
Yes, you can use a calculator to simplify cube root expressions. Most calculators have a cube root function that you can use to find the cube root of a number. However, it is still important to understand the steps involved in simplifying a cube root expression by hand.
  • Quantum Physics
