How to Simplify f(3a-4) for the Function f(x)=-4x+5?
  • MHB
  • Thread starter Monk1
  • Tags
    Simplify
In summary, to find and simplify $f(3a-4)$, we substitute $3a-4$ for $x$ in the definition of $f(x)$, which is $-4x+5$. This results in $-12a+16+5=-12a+21$ after simplification. Substitution is similar to throwing a value into a portal, where $x$ is the entry and may appear multiple or zero times as the exit.
Monk1
Let f(x)=-4x+5. Find and simplify f(3a-4)
I have the answer, but I don't know how to get there.
Missed it on a test.
Answer= = -12a+21
Mathematics news on Phys.org
When you are asked to find $f(3a-4)$, it means that you have to substitute $3a-4$ for every occurrence of $x$ in the definition of $f(x)$. The definition (i.e., the right-hand side) of $f(x)$ is $-4x+5$. It has a single occurrence of $x$. This occurrence must be replaced by $3a-4$. Thus, the result of substitution is $-4(3a-4)+5$. The remaining step is simplification. Here you have to "multiply through", i.e., apply distributivity of multiplication over addition. The expression becomes $-4\cdot(3a)-4\cdot(-4)+5$, which simplifies to $-12a+16+5=-12a+21$.
I have not played modern games, but if I am right, substitution is similar to engaging a portal. The definition like $f(x)=-4x+5$ is a portal with entry $x$ on the left-hand side and exit $x$ on the right-hand side. Applying $f(x)$ to $3a-4$ is similar to throwing $3a-4$ into the portal, so it appears unchanged at the exit. Note that even though $x$ appears once on the left-hand side of the definition of $f$, it may appear several or zero times at the right-hand side, i.e., the portal may have several or zero exits.
FAQ: How to Simplify f(3a-4) for the Function f(x)=-4x+5?
What is the purpose of the "Find and Simplify" process?
The purpose of the "Find and Simplify" process is to identify complex or convoluted ideas or concepts and simplify them for easier understanding and communication.
How does the "Find and Simplify" process work?
The "Find and Simplify" process involves breaking down complex ideas into smaller, more manageable components, and then finding ways to simplify or clarify those components through clear and concise language, visual aids, or other techniques.
What are some common techniques used in the "Find and Simplify" process?
Some common techniques used in the "Find and Simplify" process include using analogies or metaphors to explain complex concepts, creating diagrams or other visual aids, and using plain language and avoiding technical jargon.
Why is the "Find and Simplify" process important in scientific communication?
The "Find and Simplify" process is important in scientific communication because it helps make complex ideas more accessible to a wider audience, including non-experts. This can lead to better understanding and engagement with scientific concepts, and ultimately contribute to the advancement of science and technology.
Can the "Find and Simplify" process be applied to all areas of science?
Yes, the "Find and Simplify" process can be applied to all areas of science, as well as other fields and industries. Anywhere there are complex ideas or concepts, the "Find and Simplify" process can be used to make them more understandable and relatable to a broader audience.
