How to Simplify Fractional Exponents?
  • MHB
  • Thread starter CSmith1
In summary, the conversation discusses finding the answer to the problem 32^{2/5} + 64^{2/3}. The person starts by explaining their thought process for solving the problem, which involves finding the fifth root of 32 and squaring it, and then finding the square of 64 and taking the fifth root. Another person suggests reviewing how to simplify fractional exponents and provides some helpful resources to do so.
CSmith1
39
32 2/5(on top of the 32)+64 2/3(on top of the 64. I got 7(32 1/5 on top)squared =5
(64 2/3=(64 1/3) squared (2)=96 squared=2
Mathematics news on Phys.org
What did you get for each term? There are two terms added together in this problem so doing each part separately will help us understand your thought process.
ok for the first part this is what i did
1.)(32 1/5)2(squared = 32 to the 5th power(
32x5=160 so i have to find the power to give me 160 which is 32x5. so 32x32x32x32x32=5 .i got 5 for that.
2nd part 2.) 64 2/3=(64 1/3)squared...64x3=192.then i have to ask what power gives me 192. and i got 96 squared.96x96 gives me my 192 so i put the power which is =2
5+2=7
5+2=7
You start with \(\displaystyle 32^{\frac{2}{5}}\). The 2 means square 32 and the \(\displaystyle \frac{1}{5}\) or 5 in the bottom means find a number which multiplied by itself 5 times equals 32.
Your first idea was good. You tried to find \(\displaystyle 32^{\frac{1}{5}}\). To do that you need to find a number that when multiplied by itself 5 times equals 32, not that number times 5. Start with really small numbers and multiply them together 5 times. You should quickly figure that out.
Put another way, \(\displaystyle x^5 = x \cdot x \cdot x \cdot x \cdot x\) not \(\displaystyle 5x\)
i squared the 32 and got 1024
Hi CSmith, :)
Yes it's correct. You can do this problem in two ways.
1) Find \(32^{\frac{1}{5}}\) first and then square the answer to find \(32^{\frac{2}{5}}\).
2) Find \(32^{2}\) first and then take the fifth root. You have done the first part. Now what remains is to find a number \(x\) such that, \(32^{2}=1024=x^5\). Then \(x=32^{\frac{2}{5}}\)
Among these methods I think it would be easier to use the first method since \(32^{\frac{1}{5}}\) is easier to find than, \(1024^{\frac{1}{5}}\)
Kind Regards,
Sudharaka.
Thanks! after that what should i do?
Sudharaka said:
Hi CSmith, :)
Kind Regards,
Sudharaka.
can u show me an easiert method to do this sum please
I suggest that you review how to simplify fractional exponents and try to find the answer to your question along the methods described above. Some useful webpages are given below,
1) Khan Academy
2) Math is Fun
3) The Math Page
Kind Regards,
Sudharaka.
FAQ: How to Simplify Fractional Exponents?
What is the mathematical equation for "7: 32 + 64 Squared=2"?
The mathematical equation for "7: 32 + 64 Squared=2" is 7 + 32 + 64² = 2.
Can you explain the meaning of each number in the equation?
The number 7 represents the first number in the equation, while 32 represents the minutes in the time format. 64 squared represents 64 multiplied by itself, and the number 2 represents the final answer.
Is there a specific order in which the numbers should be solved?
Yes, the equation should be solved using the order of operations, which is Parentheses, Exponents, Multiplication and Division (left to right), and Addition and Subtraction (left to right).
What is the answer to the equation "7: 32 + 64 Squared=2"?
The answer to the equation is 2.
Can you provide a real-life example of when this equation might be used?
This equation could be used in calculating time differences between two time zones. For example, if you wanted to know the time in a different time zone that is 7 hours and 32 minutes ahead, and you know that it is 64 squared minutes past 2 pm, you can use this equation to find the answer.
