MHB How to Simplify Rational Expressions with Variables
  • Thread starter Thread starter captainnumber36
    Simplify
To simplify the rational expression 1/(2x-y) - 2/(x+2y), a common denominator of (2x-y)(x+2y) is used, leading to the final answer of (4y-3x)/(2x^2+3xy-2y^2). For the composition of functions f(g(x)), where f(x) = 4x/(1-x) and g(x) = -2/x, the result is 8/(x-2). The expression √a/(1+√a) is simplified by rationalizing the denominator, resulting in (√a - a)/(1-a). The discussion emphasizes the importance of treating algebraic fractions similarly to numerical fractions during simplification. Understanding these methods is crucial for handling rational expressions effectively.
captainnumber36
Problem 1:
1 / (2x-y) - 2 / (x+2y) = ?
The answer is:
(4y-3x) / (2x^2+3xy-2y^2)
Please explain.Problem 2:
f(x) = 4x/(1-x) and g(x) - 2/x, then f(g(x)) = ?
The answer is 8/(x-2)
Please explain.Problem 3:
Square Root of a / (1+ Square Root of a) = ?
The answer is (Square Root of a - a) / (1-a)
Please explain.Thank you very much in advance.
Mathematics news on Phys.org
Here is a photo of the problems if it helps: 18-20.
https://imgur.com/a/Jeis8T4
Can I ask you what $\displaystyle \frac{4}{8-4}$ is? By your reasoning for the answer to these equations, it's:
$\displaystyle \frac{4}{8-4}= \frac{\cancel{4}}{8-\cancel{4}} = \frac{1}{8}.$ But you know that $\displaystyle \frac{4}{8-4} = \frac{4}{4} = 1.$
When doing algebraic fractions, don't do anything you wouldn't do for numerical fractions.
The problem is to find [math]\frac{1}{2x- y}- \frac{2}{x+ 2y}[/math].
To add or subtract fractions, we need to get a "common denominator". Here the common denominator is (2x- y)(x+ 2y).
Multiply numerator and denominator of the first fraction by x+ 2y:
[math]\frac{1}{2x- y}\frac{x+ 2y}{x+ 2y}= \frac{x+ 2y}{(2x- y)(x+ 2y)}[/math].
Multiply numerator and denominator of the second fraction by 2x- y:
[math]\frac{2}{x+ 2y}\frac{2x- y}{2x- y}= \frac{4x- 2y}{(2x- y)(x+ 2y)}[/math].
Now we are ready to subtract the fractions:
[math]\frac{x+ 2y}{(2x- y)(x+ 2y)}- \frac{4x- 2y}{(2x- y)(x+ 2y)}= \frac{-3x+ 4y}{(2x- y)(x+ 2y)}[/math].
The given possible answers do not have the denominator factored so calculate [math](2x- y)(x+ 2y)= 2x(x+ 2y)- y(x+ 2y)= 2x^2+ 4xy- xy- 2y^2= 2x^2+ 3xy- 2y^2[/math].
The fraction is [math]\frac{4y- 3x}{2x^2+ 3xy- 2y^2}[/math]. That is answer "E".
To simplify [math]\frac{\sqrt{a}}{1+ \sqrt{a}}[/math], "rationalize the denominator". You should have learned earlier that [math](a+ b)(a- b)= a(a- b)+ b(a- b)= a^2- ab+ ab- b^2= a^2- b^2[/math] since the "ab" terms cancel. The "[math]a^2[/math]" and "[math]b^2[/math]" terms get rid of the square roots.
Here the "a+ b" is [math]1+ \sqrt{a}[/math]. Multiply both numerator and denominator of [math]\frac{\sqrt{a}}{1+ \sqrt{a}}[/math] by [math]1- \sqrt{a}[/math]: [math]\frac{\sqrt{a}}{1+ \sqrt{a}}\frac{1- \sqrt{a}}{1- \sqrt{a}}[/math][math]= \frac{\sqrt{a}- \sqrt{a}^2}{1^2- \sqrt{a}^2}=[/math][math] \frac{\sqrt{a}- a}{1- a}[/math].
That is answer "B".
Thanks to both of you! :)
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
