How to Sketch a v-t Graph from a p-t Graph Using Tangents?
In summary: The v-t graph of this ball therefore is first a diagonal line going down, then a horizontal line, and then a diagonal line going up again.This is exactly what happens with the parabolic p-t graph. At first p goes down, so Δp is negative and v is negative. Then p doesn't change, so Δp is zero and v is zero. Then p goes up, so Δp is positive and v is positive again.
C.Orio
Hi! I'm having troubles drawing a velocity-time graph from a position-time graph. I know parabolic p-t graphs have diagonal lines for their v-t graphs, but I'm not sure why. I also know tangents are important to use, but again, I don't understand why. Any clarification as to why this happens (in a way a high school student may understand :wink:) will be greatly appreciated! Thanks!
Δ Hello C, welcome to PF :smile:
You could look around here and see if you can pick up something to your liking.
It all has to do with
displacement = velocity x time.​
If the velocity is constant, it's easy. Position-time graph is a straight line with slope (tangent!) velocity.
If the velocity changes you have to consider smaller time intervals and you get something like
displacement = average velocity x Δtime​
and if you take Δtime small enough you get the velocity at that moment:
velocity = displacement / Δtime
on a position-time graph, displacement in a small time interval is Δp so to get v (for velocity), you take Δp and divide by Δtime
v = Δp / Δtime​
velocity is the slope of the position-time graph.
technically, average velocity at the mid-time of the short line whose slope you're calculating.
that is because vavg = Δx/Δt ... notice : it is rise/run .
(tangent is just making the line between points so short, that it only seems to touch one point; )
(it is nice for math, but in real lab experiments you have discrete data points at time intervals. )
quadratic x(t) graphs have zero slope at some time (how fast is it there?) with + slope or - slope after then.
these curves are really steep (is that fast, or slow?) at times that are very long time from the turn-around.
v = Δp / Δtime​
Thanks for the help! The only thing I'm still struggling with is why a parabola (p-t graph) has a diagonal line as a v-t graph. A parabola goes both positively and negatively (positive and negative slope from the tangent lines) but in the v-t graph all that is shown with only a diagonal line (according to the way the parabola is opening). This is what's really tripping me up o_O.
a parabola is really steep at long times from the turn-around.
The slope on an x(t) graph is the value then on its v(t) graph.
. . . the slope on a v(t) graph is the value on its a(t) graph ... a parabola x(t) means constant acceleration.
Remember the v = Δp / Δtime ? Well, Δp can be negative as well as positive.
If the p-t graph goes down, Δp is negative.
If the p-t graph is horizontal, the position doesn't change and Δp is zero.
And if the p-t graph goes up, Δp is positive.
It can also go in the other direction: If you throw up a ball, its height first increases: v is positive. But this v reduces quickly until the ball is at its highest point, when v = 0 at some moment. After that it falls down, so height decreases and v is negative.
Related to How to Sketch a v-t Graph from a p-t Graph Using Tangents?
What is a p-t graph?
A p-t graph, also known as a position-time graph, is a visual representation of an object's position or displacement over time. It shows the relationship between an object's position and the time it takes to travel that distance.
What is a v-t graph?
A v-t graph, also known as a velocity-time graph, is a visual representation of an object's velocity or speed over time. It shows the relationship between an object's velocity and the time it takes to reach that velocity.
What are tangents?
Tangents are lines that touch a curve at a single point, without crossing or intersecting it. In the context of graphing, tangents can help us determine the slope or rate of change at a specific point on a curve.
How do I sketch a v-t graph from a p-t graph using tangents?
To sketch a v-t graph from a p-t graph using tangents, you will need to plot points on the v-t graph using the slope of the tangents at various points on the p-t graph. The slope of the tangent at a specific point on the p-t graph represents the velocity at that point, so by plotting these points on the v-t graph, you can create a visual representation of an object's velocity over time.
Why is sketching a v-t graph from a p-t graph using tangents useful?
Sketching a v-t graph from a p-t graph using tangents can be useful for analyzing an object's motion and understanding its velocity at different points in time. It can also help us make predictions about an object's future motion based on its current velocity. Additionally, by using tangents, we can determine the acceleration of an object, as the slope of a velocity-time graph represents the object's acceleration at a given point in time.
