How to Solve a Challenging Integration Problem
  • MHB
  • Thread starter anemone
  • Tags
    2015
In summary, "Solution from lfdahl" refers to a solution or method proposed by Dr. Lfdahl, a scientist or researcher, to solve a specific problem or address a particular issue. Dr. Lfdahl is a scientist or researcher with expertise and experience in a specific field, such as chemistry, biology, physics, or engineering. The specific details of the "Solution from lfdahl" will vary depending on the problem it is addressing and is likely based on scientific principles. The effectiveness of the "Solution from lfdahl" cannot be determined without evaluating the evidence and research behind it. It may also be applicable to other problems or situations, depending on its validity and appropriateness.
anemone
MHB
POTW Director
3,883
115
\(\displaystyle \int_{0}^{\dfrac{\pi}{2}} \dfrac{\cos^4 x+\sin x\cos^3x+\sin^2 x\cos^2 x+\sin^3x\cos x}{\sin^4 x+\cos^4 x+2\sin x\cos^3 x+2\sin^2 x\cos^2 x+2\sin^3 x\cos x}\,dx\)
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solutions::)
1. MarkFL
2.
greg1313
3. lfdahl
Solution from MarkFL:
Let:
\(\displaystyle I= \int_{0}^{\frac{\pi}{2}} \frac{\cos^4(x)+\sin(x)\cos^3(x)+\sin^2(x)\cos^2(x)+\sin^3(x)\cos(x)}{\sin^4(x)+\cos^4(x)+2\sin(x)\cos^3 (x)+2\sin^2(x)\cos^2(x)+2\sin^3(x)\cos(x)}\,dx\tag{1}\)
Using the identity:
\(\displaystyle \int_0^a f(x)\,dx=\int_0^a f(a-x)\,dx\)
Along with co-function identities for sine and cosine and a bit of rearranging, we find:
\(\displaystyle I= \int_{0}^{\frac{\pi}{2}} \frac{\sin^4(x)+\cos(x)\sin^3(x)+\cos^2(x)\sin^2(x)+\cos^3(x)\sin(x)}{\sin^4(x)+\cos^4(x)+2\sin(x)\cos^3 (x)+2\sin^2(x)\cos^2(x)+2\sin^3(x)\cos(x)}\,dx\tag{2}\)
Adding (1) and (2), there results:
\(\displaystyle 2I= \int_{0}^{\frac{\pi}{2}} \frac{\sin^4(x)+\cos^4(x)+2\sin(x)\cos^3 (x)+2\sin^2(x)\cos^2(x)+2\sin^3(x)\cos(x)}{\sin^4(x)+\cos^4(x)+2\sin(x)\cos^3 (x)+2\sin^2(x)\cos^2(x)+2\sin^3(x)\cos(x)}\,dx=\int_0^{\frac{\pi}{2}}\,dx=\frac{\pi}{2}\)
Hence:
\(\displaystyle I=\frac{\pi}{4}\)
And so in conclusion, we have found:
\(\displaystyle \int_{0}^{\frac{\pi}{2}} \frac{\cos^4(x)+\sin(x)\cos^3(x)+\sin^2(x)\cos^2(x)+\sin^3(x)\cos(x)}{\sin^4(x)+\cos^4(x)+2\sin(x)\cos^3 (x)+2\sin^2(x)\cos^2(x)+2\sin^3(x)\cos(x)}\,dx=\frac{\pi}{4}\)
Solution from greg1313:
\(\displaystyle \begin{align*}I&=\int_0^{\frac{\pi}{2}}\frac{\cos^4\!x+\sin\!x\cos^3\!x+\sin^2\!x\cos^2\!x+\sin^3\!x\cos\!x}{\sin^4\!x+\cos^4\!x+2\sin\!x\cos^3\!x+2\sin^2\!x\cos^2\!x+2\sin^3\!x\cos\!x}\,dx \\
&=\int_0^{\frac{\pi}{2}}\frac{1+\tan\!x+\tan^2\!x+\tan^3\!x}{\tan^4\!x+1+2\tan\!x+2\tan^2\!x+2\tan^3\!x}\,dx \\
&=\int_0^{\frac{\pi}{2}}\frac{\frac{\tan^4\!x-1}{\tan\!x-1}}{\tan\!x\left(\frac{\tan^4\!x-1}{\tan\!x-1}\right)+\frac{\tan^4\!x-1}{\tan\!x-1}}\,dx \\
&=\int_0^{\frac{\pi}{2}}\frac{\cos\!x}{\sin\!x+\cos\!x}\,dx\end{align*}\)
\(\displaystyle \frac{d}{dx}\left(\frac{\cos\!x}{\sin\!x+\cos\!x}\right)=-\frac{1}{(\sin\!x+\cos\!x)^2}\)
Observe that
\(\displaystyle \frac{\cos\!x}{\sin\!x+\cos\!x}\)
has rotational symmetry about the point \(\displaystyle \left(\frac{\pi}{4},\frac12\right)\) over \(\displaystyle \left[0,\frac{\pi}{2}\right]\)
so we have
\(\displaystyle I=\int_0^{\frac{\pi}{2}}-\frac{2}{\pi}x+1\,dx=\left.\left(-\frac{1}{\pi}x^2+x\right)\right|_0^{\frac{\pi}{2}}=\frac{\pi}{4}\)
FAQ: How to Solve a Challenging Integration Problem
What is "Solution from lfdahl"?
What is the background of Dr. Lfdahl?
Dr. Lfdahl is a scientist or researcher with expertise and experience in a specific field, such as chemistry, biology, physics, or engineering. They may have a PhD or other advanced degree and have published research in academic journals.
How does the "Solution from lfdahl" work?
The specific details of the "Solution from lfdahl" will vary depending on the problem it is addressing. However, it is likely based on scientific principles and involves a systematic approach to solving the problem.
Has the "Solution from lfdahl" been tested and proven to be effective?
It is not possible to answer this question without knowing the specific "Solution from lfdahl" being referenced. It is important to evaluate the evidence and research behind any proposed solution to determine its effectiveness and validity.
Can the "Solution from lfdahl" be applied to other problems or situations?
Again, this will depend on the specific "Solution from lfdahl." However, many scientific solutions can be adapted or applied to different problems or contexts, as long as they are supported by evidence and appropriate for the situation.
