I How to Solve a Nonlinear PDE with Sinh Function?
Adri
The PDE is $$ \frac{1}{a^2 x^2} (u_y)^2 - (u_x)^2 =1$$ I know the solution, its ## u=x senh(ay) ##, but I dont know how I can get it. I've tried variable separation and method of characteristics but they dont seem to work.
Setting u(x,y) = X(x)Y(y) gives <br /> \frac{X^2Y&#039;^2}{a^2x^2} - X&#039;^2Y^2 = 1. You can separate this by taking <br /> \frac{X^2}{x^2} = X&#039;^2 = k^2 for some constant k. This has solution X = \pm kx. This leaves <br /> k^2(\frac{Y&#039;^2}{a^2} - Y^2) = 1 to which Y(y) = \pm\frac{1}{k}\sinh ay is a standard solution. This gives u = \pm x \sinh ay.
EDIT: Better is to start from <br /> \frac{X^2}{x^2X&#039;^2} \frac{Y&#039;^2}{a^2} - Y^2 = \frac{1}{X&#039;^2}. Making this independent of x requires X&#039;^2 = k^2 and X^2 = C^2x^2X&#039;^2 for some constants k, C. This has solution X = \pm kCx = \pm \lambda x. Then once again <br /> \frac{Y&#039;^2}{a^2} - Y^2 = \frac1{\lambda^2}.
Likes renormalize and jedishrfu
Let me expand a bit on the approach of @pasmith to find some solutions that are more general.
Your PDE can be written in the factored form ##\left(\frac{u_{y}}{ax}+u_{x}\right)\left(\frac{u_{y}}{ax}-u_{x}\right)=1##, or equivalently:$$\left(\frac{u_{y}}{ax}+u_{x}\right)=f,\;\left(\frac{u_{y}}{ax}-u_{x}\right)=f^{-1}\tag{1a,b}$$where ##f## is a function to be determined. These simultaneous equations can be solved for ##u_x,u_y##:$$u_{x}=\frac{1}{2}\left(f-f^{-1}\right),\;u_{y}=\frac{ax}{2}\left(f+f^{-1}\right)\tag{2a,b}$$Differentiating (2a) w.r.t to ##y## and (2b) w.r.t. ##x##, and equating the results, yields a PDE for ##f##:$$\left(f^{2}+1\right)\left(af-f_{y}\right)+ax\left(f^{2}-1\right)f_{x}=0\tag{3}$$Any solution ##f\left(x,y\right)## of eq.(3) can be substituted into eqs.(2) to yield a solution ##u\left(x,y\right)## of your PDE by quadratures:$$u\left(x,y\right)=\frac{1}{2}\int dx\left(f-f^{-1}\right)=\frac{ax}{2}\int dy\left(f+f^{-1}\right)\tag{4}$$Of course, eq.(3) is not obviously any easier to solve in general than your original PDE. But it is tractable for the specific case that ##f## depends on a single variable, since eq.(3) then becomes a first-order ODE.
For example, set ##f\left(x,y\right)=f\left(y\right)## in eq.(3) to find ##\left(f^{2}+1\right)\left(af-f_{y}\right)=0##, with solution ##f\left(y\right)=k_{y}e^{ay}##, where ##k_y## is an arbitrary constant of integration. Using (4), one solution of your PDE is therefore:$$u\left(x,y\right)=\frac{x}{2}\left(k_{y}e^{ay}-k_{y}^{-1}e^{-ay}\right)\tag{5a}$$(Note that putting ##k_y=1## reduces this to the specific ##x\sinh\left(ay\right)## solution you gave in your post.) Alternatively, setting ##f\left(x,y\right)=f\left(x\right)## in eq.(3) gives ##\left(f^{2}+1\right)f+x\left(f^{2}-1\right)f_{x}=0## which is solved by ##f\left(x\right)=\frac{1}{2k_{x}x}\left(1\pm\sqrt{1-4k_{x}^{2}x^{2}}\right)##. Then (4) gives the solution:$$u\left(x,y\right)=\frac{1}{2k_{x}}\left(ay\pm\left(\sqrt{1-4k_{x}^{2}x^{2}}-\tanh^{-1}\left(\sqrt{1-4k_{x}^{2}x^{2}}\right)\right)\right)\tag{5b}$$In summary, eqs.(5) represent two distinct solutions of your PDE, each of which involves an arbitrary constant of integration.
Slightly simpler is to set f = e^g, so that <br /> u_y = ax \cosh g \quad u_x = \sinh g with <br /> (g_y - a)\cosh g = ax g_x \sinh g. Now with g_x = 0 we get g = ay + c which leads to u = x\sinh(ay + c). With g_y = 0 we have \cosh g = \frac kx and <br /> u = aky \pm \int \sqrt{ \frac{k^2}{x^2} - 1 }\,dx. By the method of characteristics we can obtain the general solution as <br /> \begin{split}<br /> x &amp;= D(\eta)\operatorname{sech}(a\zeta + B(\eta)) \\<br /> y &amp;= \zeta + C(\eta) \\<br /> g &amp;= a \zeta + B(\eta) \end{split} and u can be found from \begin{split}<br /> u_\zeta &amp;= x_\zeta \sinh g + ax y_\zeta \cosh g \\<br /> &amp;= -aD \tanh^2 g + a D \\<br /> u_\eta &amp;= x_\eta \sinh g + ax y_\eta \cosh g \\<br /> &amp;= -DB&#039; \tanh^2 g + D&#039; \tanh g +aDC&#039;.\end{split} which yields <br /> u = x \sinh (a \zeta + B(\eta)) + \int aC&#039;(\eta)D(\eta)\,d\eta.
Likes renormalize
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
