How to Solve an Equation with Fractions and Variables?
  • MHB
  • Thread starter ai93
In summary, the equation x+3 over 4 = x-3 over 5 + 2 can be simplified to x+3=x-3+2. When multiplying out, you should always times top first then divide by the bottom.
ai93
54
I have an equation that I am having trouble on
any suggestions?
Mathematics news on Phys.org
You equation is:
\(\displaystyle \frac{x+3}{4}=\frac{x-3}{5}+2\)
Correct?
MarkFL said:
You equation is:
Correct?
Yes it is
mathsheadache said:
Yes it is
Okay good. :D
Now, we want to get rid of those pesky denominators...what number can we multiply both sides of the equation by, such that we will rid ourselves of those denominators?
MarkFL said:
Okay good. :D
Do we find a LCM, so times the first equation by 5 and the second by 4 so the denominator are both 20?
You are on the right track...20 is the LCM of the two denominators, so multiplying both sides by 20 will get rid of the denominators. So what do you have after multiplying both sides by 20?
So I wouldn't times each side by 4 and 5 for the LCM 20 and cancel out?
\(\displaystyle \frac{x+3}{4(x5)} = \frac{x-3}{5(x4)}+2 \) to equal
\(\displaystyle \frac{x+3}{20}=\frac{x-3}{20}+2\) then cancel out the denominators. I would be left with x+3=x-3+2. I am guessing I would move either x+3 or x-3?
This is what I am suggesting:
\(\displaystyle 20\left(\frac{x+3}{4}=\frac{x-3}{5}+2\right)\)
After multiplying each term on both sides of the equation by 20, we obtain:
\(\displaystyle 5(x+3)=4(x-3)+40\)
Now, it's a matter of distributing, and collecting like terms, and solving for $x$. :D
When multiplying out should you always times top first then divide by the bottom. So in this example, 20 * x+3 then / by 4 which = 5? Just a general question, you wouldn't times 20 * (x+3) which = 20x+60. I hope you understood that bit.
So to solve for x. We get (5x+15) = (4x-12) + 160.
(5x+15) - (4x-12) = 160
This is how I think of it...
\(\displaystyle 20\cdot\frac{x+3}{4}=20\cdot\frac{x-3}{5}+20\cdot2\)
\(\displaystyle 4\cdot5\cdot\frac{x+3}{4}=4\cdot5\cdot\frac{x-3}{5}+20\cdot2\)
\(\displaystyle \cancel{4}\cdot5\cdot\frac{x+3}{\cancel{4}}=4\cdot\cancel{5}\cdot\frac{x-3}{\cancel{5}}+20\cdot2\)
You could multiply 20 by the whole thing and then divide by 5 so like 20x+60 and then divide by 4 and you get 5x+15 but it's easier to simply first. just do 20/4 which is 5 and then you have 5(x+3)
You have 5x+15=4x-12+40.
$5(x+3)=4(x-3)+40$
$5x+15=4x-12+40$
$5x-4x=-12-15+40$
$x=?$
In the third step why did you start to times 4*5, when before it was just 20?
I see how you got to 5(x+3)=4(x-3)=40. Now like you said earlier solve for x?
Times out the bracket maybe?:
\(\displaystyle (5x+15)=(4x-12)+40\) now I am lost..
because 20 is the same as 4*5 and he wanted to show you how to simplify it so the the two 4's could be canceled out which leaves you with 5.
ineedhelpnow said:
u could multiply 20 by the whole thing and then divide by 5 so like 20x+60 and then divide by 4 and u get 5x+15 but its easier to simply first. just do 20/4 which is 5 and then u have 5(x+3)
$5(x+3)=4(x-3)+40$
$5x+15=4x-12+40$
$5x-4x=-12-15+40$
$x=?$
I understand now! From 5(x+3)=4(x−3)+40 times it out for 5x+15=4x−12+40. Then just move like terms! I sometimes forget it can be that easy..
So \(\displaystyle x=13!\)
Thanks!
No problem. Just be careful when multiplying out. Mistakes can easily be made. I still don't know where that 160 came from :p (There are like 8 people viewing this thread. I bet they're all in your class (Giggle) )
ineedhelpnow said:
no problem. just be careful when multiplying out. mistakes can easily be made. i still don't know where that 160 came from :p (there are like 8 people viewing this thread. i bet theyre all in ur class (Giggle) )
That 160 came from 4(x−3)+40. 4*40 is 160 haha. They could be, I could be helping them. It is some tricky maths! (Giggle) :D
FAQ: How to Solve an Equation with Fractions and Variables?
What is an equation?
An equation is a mathematical statement that contains an equal sign (=) and at least one variable, which represents an unknown value. The goal of solving an equation is to find the value of the variable that makes the equation true.
How do I solve an equation?
To solve an equation, you need to perform the same operation to both sides of the equal sign until you isolate the variable on one side and the constant on the other side. This can involve addition, subtraction, multiplication, division, and sometimes, exponents or roots.
What does it mean to "solve" an equation?
Solving an equation means finding the value of the variable that makes the equation true. This value is called the solution. In other words, the solution is the number that, when substituted for the variable, makes the equation a true statement.
Can an equation have more than one solution?
Yes, an equation can have more than one solution. This typically happens when the equation contains multiple variables or when the equation is a quadratic or higher-order polynomial.
How do I check if my solution is correct?
To check if your solution is correct, you can substitute the value you found for the variable back into the original equation and see if it makes the equation a true statement. You can also use a calculator or graphing software to verify your solution.
