How to Solve an Integral Problem Involving a Continuous Function?
  • MHB
  • Thread starter grgrsanjay
  • Tags
    Integral
In summary, the problem is asking to find the integrals $\displaystyle \int_0^1 f(x)dx$ and $\displaystyle \int_0^1 xf(x)dx$ for a continuous and differential function $\displaystyle f(x) = x + \int_0^1 (xy + x^2)f(y)dy$. The first integral can be found by expanding the original equation and using the fact that $\displaystyle f(y)$ is continuous, while the second integral can be found by differentiating the original equation and solving for $\displaystyle f(x)$. This leads to a general quadratic equation for $\displaystyle f(x)$, and by replacing $\displaystyle f(x)$ in the original equation
grgrsanjay
Let $f:R \to R$ be a continuous and differential function given by
find $\displaystyle \int_0^1 f(x)dx$ and $\displaystyle \int_0^1 xf(x)dx$I wanted to know how i could start the problem.Please do not give full solution
It would be good if you could even help me with the LaTeX too...
Re: Calculus problem
What I might try. Expanding your integral equation gives
$\displaystyle f(x) = x + x\int_0^1 yf(y)dy + x^2\int_0^1 f(y)dy\;\;\;(1)$
Now $f(y)$ is continuous so $\displaystyle \int_0^1 f(y)dy$ and $\displaystyle \int_0^1 y f(y)$ are constant so from (1) we have a preliminary form for $f(x)$, namely
$\displaystyle f(x) = a x + bx^2$
Then use (1).
Let me integrate it, then $\displaystyle \int_0^1 f(x)dx$ = $\displaystyle (1+\int_0^1 yf(y)dy)$. $\displaystyle \int_0^1 xdx$ + $\displaystyle { \int_0^1 f(y)dy}. \int_0^1 x^2 dx$
So , I get the equation 4A = 3 + 3B $(Lazy$ $to$ $type$ $latex...so$ $used$ $A$ $and$ $B)$
Then what equation would i get??
If you differentiate both sides of the given equation with respect to x, you get $\displaystyle f'= 1+ \int_0^1 (y+ 2x)f(y)dy$. If you differentiate again, you get $\displaystyle f'= \int_0^1 f(y)dy$ which is a constant for all x. Just call that constant A and f''= A gives f'= Ax+ B and then $\displaystyle f(x)= (A/2)x^2+ Bx+ C$, a general quadratic. Replacing f by that in the origina equation will give you three equations for A, B, and C.
FAQ: How to Solve an Integral Problem Involving a Continuous Function?
What is an integral problem?
An integral problem is a mathematical problem that involves finding the area under a curve on a graph. It is a type of calculus problem that requires solving an integral equation.
What is an integral equation?
An integral equation is a mathematical equation that contains an unknown function under an integral sign. It involves finding the function itself, rather than just its value. Solving integral equations is an important part of integral problems.
What is the difference between definite and indefinite integrals?
A definite integral is an integral with specific upper and lower limits, while an indefinite integral is an integral without specified limits. In other words, a definite integral gives a specific numeric value, while an indefinite integral gives a function.
How do you solve an integral problem?
To solve an integral problem, you must first determine the integral equation and its limits. Then, you can use various techniques such as substitution, integration by parts, or trigonometric identities to solve the integral. Finally, you can evaluate the integral and find the solution to the problem.
What are some real-world applications of integral problems?
Integral problems are used in many fields, such as physics, engineering, economics, and statistics. For example, in physics, integrals are used to calculate the work done by a force, and in economics, they are used to calculate the area under a demand curve to determine consumer surplus. In general, integrals are used to find the total amount or accumulation of something over a given interval, which has many practical applications.
