MHB How to solve following optimization problem?
  • Thread starter Thread starter user_01
    Optimization
The optimization problem presented is defined as maximizing the expression ax + by^3 under the constraints 0 ≤ x ≤ 1 and 0 ≤ y ≤ 1. This problem is confirmed to be convex since it involves a convex function over a convex set. The KKT method can be applied, but the inequality constraints can be expressed using the constraint function g(x,y) = (-x, -y, x-1, y-1). The maximum value of the function is found to be a + b at the point (1, 1), while the minimum value is 0 at (0, 0). Thus, the analysis concludes that the optimal solution is achieved at the boundary of the defined constraints.
user_01
The following is the mathematical expression for my model's rate expression. Variables $x,y$ are the controlling parameter, while the rest are positive constants.
$$\max_{x,y} \ ax + by^3 \ (s.t. \ 0\leq x \leq 1,\ 0\leq y\leq1)$$
Can I mathematically say that it is a convex problem within the limits of variables $x,y$?
The graph for the equation strictly follows the definition of convexity.
I have learned to solve the problems with KKT method, but I cannot understand how to resolve the inequality constraints $0 \leq (x,y) \leq 1$.
Mathematics news on Phys.org
Wiki explains that a convex problem is the optimization of a convex function over a convex set.
So it is indeed a convex problem as both conditions are satisfied.
Those inequality constraints translate into the constraint function $\mathbf g(x,y) = (-x,-y,x-1,y-1)$ with $g_i(x,y) \le 0$.
Btw, we can already see by inspection that the optimum must be at $(x,y)=(1,1)$ with value $a+b$.
The derivative of $ax+ by^3$ with respect to x is the constant a. If a is not 0, that derivative is never 0 so any max or min must be on the boundary. That boundary consists of 4 pieces
1) x= 0, $0\le y\le 1$. The function reduces to $by^3$ on $0\le y\le 1$ which obviously has its minimum value, 0, at y= 0 and maximum value, b, at y= 1.
2) y= 0, $0\le x\le 1$. The function reduces to $ax$ on $0\le x\le 1$ which obviouslly has its minimum value, 0, at x= 0 and maximum value , a, a x=1.
3) x= 1, $0\le y\le 1$. The function reduces to $a+ by^3$ on $0\le y\le 1$ which obviouly has its minimum, a, at y= 0 and its maximum a+ b at y= 1.
4. y= 1, $0\le x\le 1$. The function reduces to $ax+ b$ on $0\le x\le 1$ which obviouslly has its minimum, b, at x= 0 and its maximum, a+ b at x= 1.
Over all, then, the maximum is a+ b which is achieved at (1, 1). The minimum value is 0 which is achieved at (0, 0).
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
