MHB How to Solve for Equations of Demand and Supply with Given Price Elasticity?
  • Thread starter Thread starter abigmole
The discussion centers on solving for the equations of demand and supply for bananas in Small-town, Malaysia, given a market price of $0.10 per pound and a quantity sold of 1 million pounds per year. The price elasticity of demand is -5, while the short-run price elasticity of supply is 0.05. Participants suggest using linear equations to represent demand and supply curves, with the elasticity formulas provided to derive the necessary parameters. The equilibrium condition indicates that the price per quantity demanded equals the price per quantity supplied, allowing for further calculations. The key steps involve determining the values of the coefficients in the linear equations based on the given elasticities and equilibrium.
abigmole
The current price in the market for bananas is $0.10 per pound. At
this price, 1 million pounds are sold per year in Small-town, Malaysia.
Suppose that the price elasticity of demand is -5 and the short run
price elasticity of supply is 0.05. Solve for the equations of demand
and supply, assuming that demand and supply are linear.Hi, was given this question to do and I'm lost! Anyone knows how to solve this?
Would greatly appreciate any form of help! Thanks!
Mathematics news on Phys.org
Hi abigmole, :)
Let \(P\) be the price, \(Q_{d}\) be the quantity demanded and \(Q_{s}\) be the quantity supplied. Since the demand and supply curves are linear those curves could be represented by,
\[P=aQ_{d}+b\mbox{ and }P=cQ_{s}+d\]
The elasticity of demand and supply are defined by,
\[E_{d}=\frac{P}{Q_{d}}\frac{dQ_{d}}{dP}\mbox{ and }E_{s}=\frac{P}{Q_{s}}\frac{dQ_{s}}{dP}\]
\[\therefore E_{d}=\frac{1}{a}\frac{P}{Q_{d}}\mbox{ and }E_{s}=\frac{1}{c}\frac{P}{Q_{s}}\]
It is given that \(E_{d}=-5\mbox{ and }E_{s}=0.05\). Since this market is in a economic equilibrium situation, \[\frac{P}{Q_{d}}=\frac{P}{Q_{s}}=\frac{0.1\times 10^{6}}{10^{6}}=0.1\]
I hope you can do the rest yourself. You have to find the values of \(a\) and \(b\). Then consider the equilibrium point so that you can solve for \(c\) and \(d\) in the supply and demand curves.
Kind Regards,
Sudharaka.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
