How to solve for the moment of inertia and angular acceleration?
Ok I think I am starting to get this. So if I choose the hip as my axis of rotation, then that would make the hip's torque 0. Then -Tgluteus - Tthigh +Ttibia = 0. Then I enter in the force and distances to get the torques so I would have - Fglutues x Xgluteus - Fthigh x Xthigh + Ttibia x Xtibia= 0. So then... what?Now you can solve for Tgluteus. Note that you don't need to enter in the force values, you only need to set up the equation and solve for the unknown force.Now you can solve for Tglute
tellas
A girl is climbing up a set of stairs and has her femur horizontal. Her thigh weighs 12 pounds, acting at a center of mass 15 cm from her hip joint. She places 50 pounds of weight on the lower portion of that leg, vertically through her knee. Her gluteus maximus is applying a force directed 30 degrees below the horizontal, at a point 8 cm from her hip joint. An unknown force is applied at her hip.
1. How much force is her gluteus maximus exerting on her femur?
2. WHat are the magnitude and direction of the unknown force applied to her hip?
3. Approximate her thigh as a thin rod, with a mass of 12 pounds. What is her thigh's moment of inertia about either end?
4. If she increases the force from her gluteus maximus to 500 pounds, with everything else being the same, what angular acceleration will her thigh experience about her hip?
I believe relevant equations would be:
angular acceleration= T/I
I=1/3Ml^2
For number 3 I tried to solve for moment of inertia by doing I= 1/3(5.4kg)(.4^2)
I am really confused on how I would solve the rest of the problems.
You need to show a bit more effort to meet forum rules.
For 1). Try assuming there is no angular acceleration.
If I assumed there was no angular acceleration would I use F=ma?
If there is no acceleration then it becomes a statics problem. What does that mean for the net force (F) or the net torque (T)?
The net force or torque would be equal to zero. So the sum of all the forces on the femur would be equal to zero?
Net force AND net torque.
F=ma. If the femur is not accelerating, the sum of the forces must be zero.
##\tau=I\alpha## (torque = moment of inertia times angular acceleration). If the femur has zero angular acceleration, the sum of the torques must also be zero.
So can you write sum equations now :-)
I am confused on how the sum of all the forces on the femur would equal zero since all of the given forces are positive
All of the given forces are vectors.
It sounds like you need to revise how to do statics problems. If you define "up" as positive then two of the forces have positive components in that direction and two have negative components in that direction.
Personally for the first question I would start by summing torques. Do you know how to pick a suitable point to sum the torques about?
Is the femur the suitable point to sum the torques? From what I understand, there are two forces in the x (hip and gluteus) direction and four forces in the y direction (hip, gluteus, thigh, and tibia) . The torque for the thigh would be (53.38)(.15)= 8.007 and the torque of the tibia would be (222.4)(.4)= 89.76. If I assume up is positive then tibia's torque is positive and thigh's torque is negative. I do not know how I can solve for the gluteus without knowing the hip's force.
The femur is not a point at all.
If you have one or more unknown forces, consider summing the torques about the point at which one of them acts.
tellas said:
Is the femur the suitable point to sum the torques? From what I understand, there are two forces in the x (hip and gluteus) direction and four forces in the y direction (hip, gluteus, thigh, and tibia) The torque for the thigh would be (53.38)(.15)= 8.007 and the torque of the tibia would be (222.4)(.4)= 89.76. If I assume up is positive then tibia's torque is positive and thigh's torque is negative. I do not know how I can solve for the gluteus without knowing the hip's force.
It's a statics problem so the net torque about any point is zero. As jbriggs suggests, if you sum the torques about the point where an unknown force acts then it disappears from the equation (because torque = force * distance and the distance part would be zero).
Since you are working with torques you should define clockwise/anticlockwise as positive rather than up/down.
Ok I think I am starting to get this. So if I choose the hip as my axis of rotation, then that would make the hip's torque 0. Then -Tgluteus - Tthigh +Ttibia = 0. Then I enter in the force and distances to get the torques so I would have - Fglutues x Xgluteus - Fthigh x Xthigh + Ttibia x Xtibia= 0. So then I would move it to solve for the force of gluteus by making it -Fgluteus= ((+Fthigh x Xthigh) - (Ftibia x Xtibia)) / Xgluteus. -Fgluteus = ((53.4 N x .15 m) - (222.4 N x .4 m))/ .08. -Fgluteus= -845 N. Is this correct or would I have to make the gluteus the axis of rotation?
What about the angle of application for the forces?
Yes that's the best approach.
The lever arm/distance you want is the perpendicular distance... .
Likes jbriggs444
So using that video I found the perpendicular lever arm of the gluteus force by using sin(30)(8)= 4cm. I then get (-(12lbs x 15cm)+(50lbs x 40cm))/4 and get a force of 455 pounds. Is this better?
Looks right to me.
For question number 2, I set all of the forces equal to zero then moved the hip force by itself. Fgluteus+Fthigh-Ftibia= Fhip. 455 + 12 - 50 = +417lbs.
For question number 3, I used the equation I=(1/3)(mthigh)(lthigh)^2. I am not sure if I have to convert the units to kg and m, but if I do convert, I get (1/3)(5.4kg)(.4m)^2= .288 kg x m^2.
Am I doing these two questions correctly?
That's not correct. You don't know what direction the force at the hip acts at. You have two unknowns (magnitude and direction) so you need to write two equations... a sum of the vertical components to zero and a sum of the horizontal components to zero. Solve to give the two unknowns.
CWatters said:
That's not correct. You don't know what direction the force at the hip acts at. You have two unknowns (magnitude and direction) so you need to write two equations... a sum of the vertical components to zero and a sum of the horizontal components to zero. Solve to give the two unknowns.[/QUOTE
So the answer that I gave, is that correct for the vertical component? I'm a little confused on how I find the force of the gluteus vertically and horizontally. Would I use cos(30)= x/455lbs= 394 and sin(30)= x/455lbs= 227.5? If so then I would have 227.5+12-50= 189.5lbs for the vertical hip force. For the horizontal component, 394lbs=-Fhip. So Fhip=-394lbs.
Yes that's the right approach if you mean the x component of Fglutes is 394lbs and the y component is 227.5lbs.
Edit: There is nothing wrong with defining down and left as +ve but its more usual to define up and right as +ve. Don't change it now though!
Correct. Now combine them to give the magnitude and direction of Fhip.
Related to How to solve for the moment of inertia and angular acceleration?
What is the formula for moment of inertia?
The formula for moment of inertia is I = mr^2, where m is the mass of the object and r is the distance from the axis of rotation.
How do you calculate angular acceleration?
Angular acceleration can be calculated using the formula α = Δω / Δt, where Δω is the change in angular velocity and Δt is the change in time.
What is the difference between moment of inertia and angular acceleration?
Moment of inertia is a measure of an object's resistance to changes in its rotational motion, while angular acceleration is the rate of change of an object's angular velocity.
What are the units for moment of inertia and angular acceleration?
The units for moment of inertia are kg*m^2 and the units for angular acceleration are radians/second^2.
What factors affect the moment of inertia of an object?
The moment of inertia of an object is affected by its mass, shape, and distance from the axis of rotation.
