How to solve for the volume of the universe / redshift
In summary, Chronos was asking how to calculate the volume of the universe between epochs corresponding to redshifts of 1100 and 8555.
rano jojo
Hey !
i am having this question to be answered , i am new to the cosmology studies and still a bit confused about some formulas.
the question is:
(a) The greatest redshift known corresponds to the cosmic microwave background
(CMB, CBR) at redshift z 1100 (although the redshift is obtained theoretically
rather than observationally). UDFy-38135539 is a galaxy with the high redshift of
z = 8:555. By what factor did the volume of the universe increase between the
epochs corresponding to z = 1100 and z = 8:555?
what i am thinking of is using the scale factor with the relationship of the redshift for z= 1100
R= 1/1+1100 = 1/1101
then calculate the volume for a dimension universe of the z= 1100
volume = 1/1001*1/1101*1/1001*V (z=8.555)
is that corrects ?
otherwise how i can be solving this question.
thanks
Space news on Phys.org
Note that you should not talk about the volume of the universe, because that is an unknown. Rather say "what is the ratio of the scale factors for the two redshifts?"
The scale factor a = z+1, where the present a=1. Using this information, the answer to this question is simple to calculate.
many thanks but i still cannot get it. i thought of solving for the R = 1/1+z of both galaxies and substract the two values to reach the the volume increase between the two epochs.
The scale factor correlates with distance increase, not volume increase. And sorry, in a hurry, I forgot the divide, because I should have written a = 1/(z+1), not z+1.
The CMB (at redshift 1089) presently is 1090 time farther from us than what it was when those photons were emitted. Your galaxy at z= 8.55 is today 9.55 time farther than what it was when the photons we from it see were emitted.
In order to calculate volumes, you must convert redshifts to distances by means of the Hubble constant, and then calculate volumes. Do you know how to do that? (I see that you have marked the thread "I" for Intermediate, so we assume you already know the basic stuff).
many thanks for your kindhelp but i tried to convert it but couldn't work , as i am still new to the studies of cosmology . would you elaborate more to help me out please?
thank you again
Rano, I can just show you how to do it, but that will not help you much. On the other hand, I cannot give you a complete beginner's course here either. If you are just interested in the ratio between the volumes, there is an easy shortcut:
The distance ratio represented by your two redshifts is $$\frac{D_1}{D_2} = \frac{1090+1}{8.55+1} =114.24$$
Now, volumes are proportional to the cubes of distances, so the volume ratio will just be the cube of that.
In order to find the real distances and volumes, you must be able to convert redshift to recession rate and then use the Hubble constant to find the present (comoving) distance. How much of that have you already studied?
many thanks , but what i believe that i will find the ration then multibly it by 3 times as the universe id 3 dimension and that would be the ratio!
I hope you mean "multiply it by itself 3 times" - because it needs to be to the power 3.
1+z is not the same as (1+z).
thank you, this is what i meant multiplying itself by the power of three and not multiplying the number by 3.
so is this correct or not?
really ? how? what is the difference please
Yes, I think you've got it now.
I think Chronos referred to your first post's R= 1/1+1100 = 1/1101, where the brackets were missing.
Related to How to solve for the volume of the universe / redshift
1. How do scientists estimate the volume of the universe?
Scientists estimate the volume of the universe by using mathematical models and measuring the observable universe. This involves measuring the size and distribution of galaxies, as well as the expansion rate of the universe.
2. What is redshift and how does it relate to the volume of the universe?
Redshift is a phenomenon in which light from distant galaxies appears to be shifted towards the red end of the electromagnetic spectrum. This is caused by the expansion of the universe and can be used to estimate the distance of these galaxies. The larger the redshift, the further away the galaxy is and the larger the volume of the universe that it occupies.
3. Can we accurately measure the volume of the entire universe?
Currently, scientists can only estimate the volume of the observable universe, which is the portion of the universe that we can see and measure. The total volume of the entire universe is still unknown and may be infinite.
4. How do scientists use redshift to study the evolution of the universe?
By measuring the redshift of light from distant galaxies, scientists can determine the rate at which the universe is expanding. This can provide insights into the age of the universe and how it has evolved over time.
5. Is there a single formula to solve for the volume of the universe and redshift?
No, there is not a single formula to solve for the volume of the universe and redshift. Scientists use a combination of mathematical models, observations, and data analysis to estimate the volume of the universe and measure redshift. The calculations and methods used may vary depending on the specific research being conducted.
