How to solve for x in a nested polynomial equation?
  • MHB
  • Thread starter anemone
In summary, a polynomial equation is nested if it contains multiple sets of parentheses within the equation. The first step in solving a nested polynomial equation for x is to distribute any outer parentheses using the Distributive Property. You do not need to solve each set of parentheses separately, as you can simplify the equation by combining like terms within each set of parentheses. After distributing the outer parentheses, the next step is to combine like terms within each set of parentheses. If there are multiple variables in the equation, you may need to use the distributive property again or combine like terms in order to solve for x.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Given that $f(x)=x^2+12x+30$. Solve for the equation $f(f(f(f(f(x)))))=0$.
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution!(Cool)
1. castor28
2. MegaMoh
Partial credit goes to lfdahl for his partially correct solution!
Solution from castor28:
Let us write $f^n$ for the n-fold composition of $f$, so that $f^0(x) = x$ and $f^{n+1}(x) = f(f^n(x))$. We must solve $f^5(x)=0$.
The graph of $f$ has a minimum at $(-6,-6)$. This shows that $-6$ is a fixed point of $f$, and makes it worthwhile to try the substitution $x=z-6$. Under that substitution, we get:
f(z-6) = z^2 - 6
and, by induction,
f^n(z-6) = z^{2^n}-6
We must now solve:
f^5(x) = f^5(z-6) = z^{32}-6 = 0
giving the real roots $z=\pm\sqrt[32]{6}$ and $x=-6\pm\sqrt[32]{6}$.
The complex solutions are $x=-6 + \sqrt[32]{6}\,e^{\frac{2\pi ni}{32}}$, with $0\le n<32$.
FAQ: How to solve for x in a nested polynomial equation?
How do I identify a nested polynomial equation?
A nested polynomial equation is an equation that contains multiple sets of parentheses, with each set containing a polynomial expression. It may also contain exponents and variables. An example of a nested polynomial equation is (3x + 2)(x^2 + 5x - 7) = 0.
What is the first step in solving a nested polynomial equation?
The first step in solving a nested polynomial equation is to simplify the equation by using the distributive property to remove the parentheses. This will result in a single polynomial equation with no nested expressions.
How do I solve for x in a nested polynomial equation with multiple variables?
If the nested polynomial equation contains multiple variables, you can use the substitution method to solve for x. Choose one variable to solve for and substitute it with a value from one of the other equations. Then, continue to solve for the remaining variables until you have a single polynomial equation with only one variable.
Can I solve a nested polynomial equation using the quadratic formula?
Yes, if the nested polynomial equation is in the form of ax^2 + bx + c = 0, you can use the quadratic formula to solve for x. However, you may need to simplify the equation first by using the distributive property.
What should I do if I cannot solve for x in a nested polynomial equation?
If you are unable to solve for x in a nested polynomial equation, it is possible that the equation has no real solutions. This means that there is no value of x that will make the equation true. In this case, you can use graphing or numerical methods to approximate the solutions or determine that there are no solutions.
