How to Solve the Absolute Value Inequality x|x-3|<-1 for 3x+1?
  • MHB
  • Thread starter mathdad
In summary, the conversation discusses how to eliminate absolute value in an inequality and solve for the range of x values that satisfy the inequality. It is determined that for x values greater than 3, the range is 3≤x≤(3±√13)/2, and for x values less than 3, the range is (3±√5)/2≤x≤(3±√13)/2. The value of a and b is not explicitly mentioned.
mathdad
1,283
See question for question.
Mathematics news on Phys.org
The first thing I would do is remove the "absolute value". If x> 3 then x- 3>0 so |x- 3|= x- 3. The inequality becomes [tex]x(x- 3)= x^2- 3x\le 1[/tex] We can write that as [tex]x^2- 3x- 1\le 0[/tex].
The equation, [tex]x^2- 3x- 1= 0[/tex] has roots [tex]x= \frac{3\pm\sqrt{13}}{2}[/tex]. This is a parabola that opens upward so the inequality is satisfied for x between those two points. Taking the positive sign, [tex]\frac{3+ \sqrt{13}}{2}[/tex] is about 4.67, just slightly larger than 3. Since we require here that x> 3, we require that [tex]3\le x\le \frac{3\pm\sqrt{13}}{2}[/tex].
If x< 3, |x- 3| is negative so [tex]x|x- 3|= -x(x- 3)= 3x- x^2[/tex]. The inequality becomes [tex]3x- x^2\le 1[/tex] or [tex]x^2- 3x+ 1\ge 0[/tex]. The equation [tex]x^2- 3x+ 1[tex] has roots [tex]\frac{3\pm\sqrt{5}}{2}[/tex]. This time the inequality is satisfied for x outside those points. [tex]\frac{3+ \sqrt{5}}{2}[tex] is approximately 2.6, less than 3. Of course [tex]\frac{3- \sqrt{5}}{2}[/tex] is less than 3. So this inequality is satisfied by [tex]x\le \frac{3- \sqrt{5}}{2}[/tex] and [tex]\frac{3+\sqrt{5}}{2}\le x\le \frac{3\pm\sqrt{13}}{2}[/tex].
RTCNTC said:
I seek the first 2 steps.
Step 1: get paper
Step 2: get pencil with eraser
I cannot read your reply on my phone. The words block most of the LaTex. In any case, what is the value of a and b? Are you saying that the value of a and b is the fraction involving the sqrt{13} on the numerator?
Is this better?
If x< 3, |x- 3| is negative so [tex]x|x- 3|= -x(x- 3)= 3x- x^2[/tex]. The inequality becomes [tex]3x- x^2\le 1[/tex] or [tex]x^2- 3x+ 1\ge 0[/tex]. The equation [tex]x^2- 3x+ 1[/tex] has roots [tex]\frac{3\pm\sqrt{5}}{2}[/tex]. This time the inequality is satisfied for x outside those points. [tex]\frac{3+ \sqrt{5}}{2}[/tex] is approximately 2.6, less than 3. Of course [tex]\frac{3- \sqrt{5}}{2}[/tex] is less than 3. So this inequality is satisfied by [tex]x\le \frac{3- \sqrt{5}}{2}[/tex] and [tex]\frac{3+\sqrt{5}}{2}\le x\le \frac{3\pm\sqrt{13}}{2}[/tex].
From the last inequality involving $x$, what do you have to do to $x$ to obtain $3x + 1$ ?
I made a typo. There should be no x in front of the absolute value.
Joppy said:
Is this better?From the last inequality involving $x$, what do you have to do to $x$ to obtain $3x + 1$ ?
A friend responded to my question this way:
|x - 3| ≤ 1
-1 ≤ x - 3 ≤ 1
3 * (-1) ≤ 3 * (x - 3) ≤ 3 * 1
-3 ≤ 3x - 9 ≤ 3
-3 + 10 ≤ 3x - 9 + 10 ≤ 3 + 10
7 ≤ 3x + 1 ≤ 13
a = 7, b = 3
Is this correct?
Where did 10 come from in his reply?
RTCNTC said:
|x - 3| ≤ 1
-1 ≤ x - 3 ≤ 1
-3 ≤ 3x - 9 ≤ 3
7 ≤ 3x + 1 ≤ 13
a = 7, b = 3
Is this correct?
Yes, though it might have been simpler to get $x$ by itself from the first line.
I will try more similar questions at home. If I get the wrong answer or get stuck, I will post all three questions with my work shown.
Did you read my previous PM about posting useless comments?
No comment is useless.
The statements:
don't have any value or 'use' to anyone here reading them. It's good that you are trying more questions, but it's a bit like if I told you that this afternoon I'm going to go shopping and buy some milk and bread.
Joppy said:
The statements:
I totally understand what you're saying. I just thought that revealing some of my daily activities would make for extra conversation. However, I will only stick to math and math only.
|x - 3| ≤ 1
-1 ≤ x - 3 ≤ 1
-3 ≤ 3x - 9 ≤ 3
7 ≤ 3x + 1 ≤ 13
a = 7, b = 3
Is this correct?
FAQ: How to Solve the Absolute Value Inequality x|x-3|<-1 for 3x+1?
What is the purpose of solving this equation?
The purpose of solving this equation is to find the values of x that satisfy the inequality and make it true.
How do I go about solving this equation?
To solve this equation, you can use algebraic techniques such as isolating the absolute value expression and considering different cases depending on the value of x.
Can I use a graphing calculator to solve this equation?
Yes, you can use a graphing calculator to solve this equation by graphing the left and right sides of the inequality and finding the points of intersection.
What are the possible solutions for this equation?
The possible solutions for this equation are all real numbers that make the inequality true. Depending on the value of x, there may be no solutions, one solution, or an infinite number of solutions.
How can I check if my solution is correct?
To check if your solution is correct, you can substitute the value of x into the original inequality and see if it makes the inequality true. You can also graph the solution on a number line and see if it falls within the shaded region of the inequality.
