How to solve the equation with square roots
In summary: If I am not using the correct rule, then I will get an incorrect answer. In summary, the equation is y=5x^2\sqrt{2x^3}{\frac{15x^7}{\sqrt{x}}}.
a1dogtraining
I am having trouble to find out what rule to use when solving this equation:
y=5x^2 square root of (2x^3)/15x^7 square root x
How do you right square roots on the keyboard. As you can see I am quit new to this forum
I have tried to use the chain rule and the quotiant rule. But when I use a different rule I get a different answer.
Is this the correct equation? (you can see the markup by quoting me)
[tex]y=5x^2 \sqrt{\frac{2x^3}{15x^7}\sqrt{x}}[/tex]
No
I think it is [tex]y=5x^2 {sqrt{2x^3}}\15x^7{sqrt{x}}[/tex]
This is what I mean sorry for that
[tex]y=5x^2\sqrt{2x^3}{frac{15x^7}\sqrt{x}} tex][/QUOTE]
a1dogtraining said:
[tex]y=5x^2\sqrt{2x^3}{\frac{15x^7}{\sqrt{x}} [/tex]
You can differentiate x to a fractional powers the same way you can differentiate x to an integral power. Try simplifying it first.
Thanks anyway I cann't get the question right. The 5x^2 and sqrt(2x^3) are on the top
and 15x^7 and sqrt(x) are on the bottom. let's try that.
So
[tex]\frac{5x^2\sqrt{2x^3}}{15x^7\sqrt{x}}[/tex]?
As qntty suggested, you can write the square root as a fractional power: [itex]\sqrt{x}= x^{1/2}[/itex].
Your expression is
[tex]\frac{5\sqrt{2}x^2x^{3/2}}{15x^7x^{1/2}}= \frac{5\sqrt{2}x^{2+3/2}}{15x^{7+ 1/2}}= \frac{5\sqrt{2}x^{7/2}}{15x^{15/2}}[/tex]
[tex]= \frac{\sqrt{2}}{3}x^{7/2}x^{-15/2}= \frac{\sqrt{2}}{3}x^{-4}[/tex]
That should be easy to differentiate.
Thank you very much. Can you just tell me what rule you used, so I can apply it to other equations.
I used a number of "rules". I used the fact that [itex]\sqrt{x}= x^{1/2}[/itex], I used the laws of exponents to reduce the problem to a single power of x, and I used the power rule to differentiate.
FAQ: How to solve the equation with square roots
How do I simplify an equation with square roots?
Simplifying an equation with square roots involves using the rules of exponents and applying basic algebraic operations. First, you can remove any perfect square factors from under the square root symbol. Then, you can combine like terms and isolate the variable on one side of the equation.
Can I solve an equation with square roots without using the quadratic formula?
Yes, there are other methods for solving equations with square roots, such as factoring or completing the square. However, the quadratic formula is a reliable and straightforward method for solving these types of equations, especially when the equation cannot be easily factored.
What should I do if my equation has a square root on both sides?
If your equation has a square root on both sides, you can square both sides of the equation to eliminate the square roots. However, this may introduce extraneous solutions, so it is important to check your answer by plugging it back into the original equation to make sure it is a valid solution.
Can I solve an equation with square roots if the variable is under the radical?
Yes, you can still solve an equation with square roots if the variable is under the radical. The goal is to isolate the variable on one side of the equation, so you may need to perform multiple operations to get the variable out from under the radical. Just remember to perform the same operation on both sides of the equation to maintain its equality.
Are there any special rules for solving equations with imaginary solutions?
Yes, when solving equations with square roots that result in a negative number under the radical, the solution will involve imaginary numbers. To solve these equations, you can use the imaginary unit, denoted as "i," which is defined as the square root of -1. You can also use the quadratic formula, which will result in a complex number solution.
