How to Solve the Integral Problem ∫(tan3x/sec2x)dx?
  • MHB
  • Thread starter paulmdrdo1
  • Tags
    Integral
In summary: C~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~4.\;\int\sin x\cos x\,dx \:=\:\int\sin x\,d(\sin x)Let u = \sin x \quad\Rightarrow\quad du = \cos x\,dxSubstitute: .\int u\,du \:=\:\tfrac{1}{2}u^2+CBack-substitute: .\tfrac{1}{2}\sin^2x + C~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~5
paulmdrdo1
385
∫(tan3x/sec2x)dx
this is what i do:
∫(tan3xsec-2x)dx
∫(tan2xtanxsec-1xsec-1x)dx
∫(sec2x-1)tanxsec-1xsec-1x)dx
let u = secx;
du = tanxsecxdx
now I'm stuck! please help.:confused:
Re: another integ problem.
I think my approach would be to rewrite the integrand as follows:
\(\displaystyle \frac{\tan^3(x)}{\sec^2(x)}=\frac{\sin^3(x)}{\cos^3(x)}\cos^2(x)=\frac{-\sin(x)\left(\cos^2(x)-1 \right)}{\cos(x)}\)
Now you should see a $u$-substitution that will work quite nicely.
i used that technique makfl and i get the right answer. but for educational purposes i want to know another way of solving that.
this what i do a while ago.
∫(tan3x/sec2x)dx
∫(tan2xtanx/sec2x)dx
∫(sec2x-1)tanx)/sec2x)dx
∫(sec2xtanx-tanx)/sec2x)dx
∫[(sec2xtanx)/sec2x - tanx/sec2x]dx
∫tanxdx - ∫(tanx/sec2x)dx
ln|secx| - ∫(sinx/cosx*cos2x)dx
ln|secx| - ∫sinxcosxdx
u= sinx; du = cosxdx
ln|secx| - ∫udu
ln|secx| - u2/2
ln|secx| - sin2x/2 + C
is my solution correct..it is different with the one i get when i used the technique you suggested.
Re: another integral problem.
Yes, your solution is also correct, and many times when we find differing forms for an indefinite integral, we find that they (without the constant of integration) differ only by a constant, which of course is allowed.
So, let's look at the two solutions without the constants:
(1) \(\displaystyle \frac{1}{2}\cos^2(x)-\ln|\cos(x)|\)
(2) \(\displaystyle \ln|\sec(x)|-\frac{1}{2}\sin^2(x)\)
First, we should observe that:
\(\displaystyle \ln|\sec(x)|=\ln|(\cos(x))^{-1}|=-\ln|\cos(x)|\)
So, if we subtract one solution from the other, we should obtain a constant. Subtracting (2) from (1), we get:
\(\displaystyle \frac{1}{2}\cos^2(x)+\frac{1}{2}\sin^2(x)\)
Using a Pythagorean identity, we now have:
\(\displaystyle \frac{1}{2}\)
So, we see that the two solutions differ by a constant, which means they are equivalent as an anti-derivative.
Perhaps a simpler way to look at it is to take the solution you obtained, and rewrite it:
\(\displaystyle \ln|\sec(x)|-\frac{1}{2}\sin^2(x)+C=-\ln|\cos(x)|-\frac{1}{2}\left(1-\cos^2(x) \right)+C=\frac{1}{2}\cos^2(x)-\ln|\cos(x)|+\left(C-\frac{1}{2} \right)\)
Since an arbitrary constant less one half, is still an arbitrary constant, we get:
\(\displaystyle \frac{1}{2}\cos^2(x)-\ln|\cos(x)|+C\)
i just want to ask how is ln|secx| = -ln|cosx|... the rest of explanation is enligthening. thanks a lot!
Recall the logarithmic property:
\(\displaystyle \log_a\left(b^c \right)=c\cdot\log_a(b)\)
and the definition:
\(\displaystyle \sec(x)\equiv\frac{1}{\cos(x)}=(\cos(x))^{-1}\)
Hello, paulmdrdo!
The integral [tex]\int \sin x\cos x\,dx[/tex] is famous
for having different (but equivalent) answers.
[tex]1.\: \int \sin x(\cos x\,dx)[/tex]
Let [tex]u \,=\,\sin x \quad\Rightarrow\quad du \,=\,\cos x\,dx[/tex]
Substitute: .[tex]\int u\,du \:=\:\tfrac{1}{2}u^2+C[/tex]
Back-substitute: .[tex]\tfrac{1}{2}\sin^2x + C[/tex]
[tex]2.\;\int \cos x(\sin x\,dx)[/tex]
Let [tex]u = \cos x \quad\Rightarrow\quad du = \text{-}\sin x\,dx \quad\Rightarrow\quad \sin x\,dx = \text{-}du[/tex]
Substitute: .[tex]\int u(\text{-}du) \:=\:\text{-}\int u\,du \:=\:\text{-}\tfrac{1}{2}u^2+C[/tex]
Back-substitute: .[tex]\text{-}\tfrac{1}{2}\cos^2x + C[/tex]
[tex]3.\;\int\sin x\cos x\,dx \:=\:\tfrac{1}{2}\int2\sin x\cos x\,dx [/tex]
. . . [tex]=\;\tfrac{1}{2}\int\sin2x\,dx \:=\:\text{-}\tfrac{1}{4}\cos2x + C[/tex]
FAQ: How to Solve the Integral Problem ∫(tan3x/sec2x)dx?
What is an integral problem?
An integral problem is a mathematical problem that involves finding the area under a curve or the accumulation of a quantity over a certain interval.
How do you solve an integral problem?
To solve an integral problem, you can use a variety of techniques including integration by substitution, integration by parts, or using specific rules such as the power rule or the chain rule.
What is the importance of solving integral problems?
Solving integral problems is important in many fields of science and engineering as it allows us to calculate quantities such as displacement, velocity, acceleration, and mass flow rate. It also helps in understanding the behavior of systems and making predictions.
Can integral problems have multiple solutions?
Yes, integral problems can have multiple solutions. This is because there are different techniques and methods that can be used to solve them, and each method may lead to a different solution. Additionally, some integral problems may have indefinite solutions, meaning that there are infinitely many possible solutions.
How can I check if my solution to an integral problem is correct?
To check if your solution to an integral problem is correct, you can use various methods such as graphing the original function and the antiderivative, using the fundamental theorem of calculus, or verifying your solution using differentiation.
