MHB How to solve this boundary value problem-Method of separation of variables
mathmari
MHB
Hey! :o
I have a question.. (Wasntme)
When we have the following boundary value problem:
$$u_{xx}+u_{yy}=0, 0<x<a, 0<y<b (1)$$
$$u_x(0,y)=u_x(a,y)=0, 0<y<b$$
$$u(x,0)=x, u_y(x,b)=0, 0<x<a$$using the method of separation of variables, the solution would be of the form $u(x,y)=X(x) \cdot Y(y)$
$$(1) \Rightarrow X''Y+XY''=0 \Rightarrow \frac{X''}{X}+\frac{Y''}{Y}=0 \Rightarrow \frac{X''}{X}=- \frac{Y''}{Y}=- \lambda$$
So we have the following problems:
$$\left.\begin{matrix}
X''+\lambda X=0, 0<x<a\\
X'(0)=X'(a)=0
\end{matrix}\right\}(2)$$
and
Y''-\lambda Y=0, 0<y<b\\
Y'(b)=0
\end{matrix}\right\}(3)$$
$$u(x,0)=X(x)Y(0)=x$$
So solving the problem $(2)$ we get the eigenvalues and the corresponding eigenfunctions.
If we have the following boundary value problem:
$$u_{xx}+u_{yy}=0, 0<x<1, 0<y<1 (1')$$
$$u(0,y)=0, u(1,y)= \sin{(\pi y)} \cos{(\pi y)}, 0<y<1$$
$$u(x,0)=u(x,1)=0, 0<x<1$$
$$(1') \Rightarrow X''Y+XY''=0 \Rightarrow \frac{X''}{X}+\frac{Y''}{Y}=0 \Rightarrow \frac{X''}{X}=- \frac{Y''}{Y}= \lambda$$
X''-\lambda X=0, 0<x<1\\
X(0)=0
\end{matrix}\right\}(2')$$
and
Y''+\lambda Y=0, 0<y<1\\
Y(0)=Y(1)=0
\end{matrix}\right\}(3')$$
$$u(1,y)=X(1)Y(y)= \sin{(\pi y)} \cos{(\pi y)}$$
So do we have to solve in this case the problem $(3')$ to find the eigenvalues nd the corresponding eigenfunctions?
Or did I have to set $\frac{X''}{X}=- \frac{Y''}{Y}=- \lambda$ instead of $\frac{X''}{X}=- \frac{Y''}{Y}= \lambda$, as at the other boundary value problem? (Wondering)
Or could we solve this problem as followed? (Wondering)
$$u(x,y)=v(x,y)+s(x)$$
$$v_{xx}+v_{yy}+s''(x)=0, 0<x<1, 0<y<1$$
$$v(0,y)+s(0)=0, 0<y<1$$
$$v(1,y)+s(1)=\sin{( \pi y)} \cos{( \pi y)}, 0<y<1$$
$$v(x,0)+s(x)=v(x,1)+s(x)=0, 0<x<1$$
$$s''(x)=0, 0<x<1$$
$$s(0)=0, s(1)= \sin{( \pi y)} \cos{( \pi y)}$$
$$v_{xx}+v_{yy}=0, 0<x<1, 0<y<1$$
$$v(0,y)=0, v(1,y)=0, 0<y<1$$
$$v(x,0)=v(x,1)=-s(x), 0<x<1$$
$$s''(x)=0, 0<x<1$$
The solution of the problem $$s''(x)=0, 0<x<1$$
is $s(x)=\sin{( \pi y)} \cos{( \pi y)} x$, isn't it? (Wondering)To solve the problem $$v_{xx}+v_{yy}=0, 0<x<1, 0<y<1$$
$$v(0,y)=0, 0<y<1$$
$$v(1,y)=0, 0<y<1$$
we use the method of separation of variables, the solution is of the form $v(x,y)=X(x)Y(y)$
So we become the following two problems:
X''+ \lambda X=0, 0<x<1\\
X(0)=X(1)=0
\end{matrix}\right\}(*)$$
Y''- \lambda Y=0, 0<x<1\\
Y(0)=Y(1)=-s(x)=-\sin{( \pi y)} \cos{( \pi y)} x
\end{matrix}\right\}(**)$$
Right? (Wondering)
From the problem $(*)$ we get that the eigenvalues are $\lambda_n=n^2 \pi^2$ and the corresponding eigenfunctions are $X_n(x)=\sin{(n \pi x)}$.
From the problem $(**)$, we get $Y(y)=c_n e^{-n \pi y}+d_n e^{n \pi y}$, don't we?
$Y(0)=-s(x) \Rightarrow c_n+d_n=-\sin{( \pi y)} \cos{( \pi y)} x$
Is this relation correct? Can we set at the left part $y=0$ and the right part of the relation there is still the variable $y$? (Wondering)
Erm... this seems to be quite a work in progress... (Sweating)
You seem to know what you're doing! (Nod)
Or do you still have questions? (Wondering)
I finally used the first way I mentioned at my first post, I mean using the method of separation of variables ($u(x,y)=X(x)Y(y)$) and found that $Y_n(y)=\sin{(n \pi y)}$ and $X_n(x)=A_n \sinh{(n \pi x)}$. So the solution is $$u(x,y)=\sum_{n=1}^{\infty}{A_n \sinh{(n \pi x)}\sin{(n \pi y)}}$$
Then using the conditions the final solution is $$u(x,y)=\frac{1}{2 \sinh{(2 \pi})} \sinh{(2 \pi x)} \sin{(2 \pi y)}$$ which satisfies the conditions! (Sun)
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
