How to solve this compound question?
  • Thread starter transgalactic
In summary, the conversation is about finding the necessary amount of Fe and oxygen to produce 0.5 kilograms of Fe_2O_3 using the given formula. The formula is discussed and the concept of moles is mentioned, as well as the ideal gas equation for converting volume to grams. The speaker encourages the other person to think on their own and determine the number of moles needed for the reaction.
transgalactic
1,395
i got this formula
[itex]
2Fe +3O_2 -> 2FeO_3
[/itex]
how many grams of Fe and litters of oxigen do i need
in order to get 0.5 kilogram of
[itex]
Fe_2O_3
[/itex]
i can find how much grams weighs each mole of each molecule?
i don't know how to do the rest
ok i understand
3 moles of
[itex]
O_2
[/itex]
can react at most with 2 moles of Fehow do i transform the volume of a gas into grams?
pV=nRT, ideal gas equation.
ok by pst 22.4 litters for every mole of gas
i can find the weight of each mole
what now?
Now you start thinking on your own, we are not here to spoonfeed you.
How many moles of product?
How many moles of reactants needed?
FAQ: How to solve this compound question?
How do I approach solving a compound question?
To solve a compound question, you should break it down into smaller, simpler parts. Then, solve each part individually and combine the solutions to get the final answer.
What are some strategies for solving a compound question?
Some strategies for solving a compound question include identifying key words and phrases, creating a diagram or table to organize information, and using algebraic equations or formulas.
How do I know which operations to use when solving a compound question?
The operations used to solve a compound question will depend on the type of question and the information given. It is important to carefully read and understand the question before selecting the appropriate operations.
Can I solve a compound question using multiple methods?
Yes, it is possible to solve a compound question using different methods. It is important to choose the method that you are most comfortable with and that will lead to the most accurate answer.
What should I do if I get stuck while solving a compound question?
If you get stuck while solving a compound question, take a break and come back to it later with a fresh perspective. You can also try re-reading the question or asking for help from a teacher or classmate.
