How to solve this network of resistors for equivalent resistance?
The discussion focuses on solving a network of resistors for equivalent resistance, specifically identifying parallel resistors. Participants note that segments PA and PB, as well as QA and QB, are in parallel. By solving these, they determine that each side of segment AB has a resistance of 2 ohms in series, resulting in an equivalent resistance of 4 ohms. The conversation emphasizes the importance of recognizing parallel connections and the potential impact of circuit configuration on resistance calculations. Overall, the participants successfully clarify the resistor arrangement and arrive at the correct equivalent resistance.
Harsharma17
The question asks to find the equivalent resistance for this group of resistors in a network.
I used Ohm's law and parallel and series combination to solve it, but don't know where to start. I thought about using Kirchoff's laws, but still I can't find the answer.
Did you spot any resistors that are in parallel?
Likes Harsharma17
Straight segment AB looks like the letter I. Would anything change if you replaced it with more straight segments that look like the letter H and tied the two resistors on the left to the left side of the H and likewise for the right side?
Remember, the convention is that, in a schematic circuit, any point on a straight line segment is at the same potential as any other point as long as there are no circuit elements, e.g. resistors, batteries, etc., in between.
Likes Harsharma17
Thanks for the reply!
Going through your suggestion, I think PA and PB are in parallel, and QA and QB are also in parallel. Solving them would lead to 2 ohm on each side of AB in series. And the equivalent resistance would be 4 ohm.
I got the answer! Thanks for the help.
Yes, now I able to separate them in parallel circuits.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
