Tyrion101
- 166
- 2
I've never been quite sure? Is it just a case of trial and error? Or just knowing the limits of sin, cos and tan?
I think I do.phinds said:I still can't figure out what it is that you are asking.
To determine if a triangle has two solutions, you need to use the triangle inequality theorem. This theorem states that the sum of any two sides of a triangle must be greater than the third side. If this condition is met, then the triangle has two solutions.
No, a triangle can only have a maximum of two solutions. If the sum of any two sides is equal to the third side, then the triangle will only have one solution, which is considered a degenerate triangle.
A triangle with two solutions is a regular triangle that has three distinct sides, while a degenerate triangle only has two distinct sides and the third side is equal to the sum of the other two sides.
Yes, a right triangle can have two solutions if the sum of its two smaller sides is greater than the length of the hypotenuse. In this case, the triangle will have two acute angles.
The triangle inequality theorem is used in many real-life situations, such as construction and architecture. It ensures that the lengths of the sides of a triangle are feasible and can be constructed, preventing any structural issues. It is also used in navigation and mapmaking to determine the most efficient routes between points.
