How to treat moment release in FBD
In summary, the compound beam ABC has a guided support at A and a fixed support at C, with a pin connection at B. To find the deflection under the load P, the moment-area method or conjugate-beam method can be used by breaking the beam at the pin connection and adding two equal and opposite moments at B. The moment at the pin connection is zero due to the moment release.
jmarcian
from book
"The compound beam ABC shown in the figure has a guided support at A and a fixed support at C. The beam consists of two members joined by a pin connection (i.e moment release) at B. find deflection 'del' under the load P"
http://photos-a.ak.fbcdn.net/photos-ak-snc1/v688/183/78/25803658/n25803658_38292392_5314.jpg
i guess just knowing your FBD!
http://photos-b.ak.fbcdn.net/photos-ak-snc1/v688/183/78/25803658/n25803658_38292393_5680.jpg
sorry but the images are reversed, i figure we are all smart people and can see the mirror images in our minds. so in my drawing i broke the beam at the couple, and drew two equal and opposite moments, is this correct? because the moment at the couple should be zero, right? and having two opposing moments would cause that. please let me know if this is right! thanks!
Thank you for your post. Yes, you are correct in breaking the beam at the pin connection and adding two equal and opposite moments at B. This is because, as you mentioned, the moment at the pin connection should be zero since it is a moment release.
To find the deflection, you can use the moment-area method or the conjugate-beam method. Both methods involve finding the moment and deflection equations for the individual members and then combining them to find the overall deflection.
I hope this helps. Let me know if you have any further questions.
I would like to clarify that moment release in FBD (Free Body Diagram) refers to the condition when a beam or structure has a pin connection, allowing it to rotate freely at that point. In this case, the pin connection at B allows the two members of the compound beam to rotate separately, creating a moment release condition.
To properly treat moment release in FBD, we need to consider the reaction forces and moments at each support point. At support A, there will be a vertical reaction force and a horizontal reaction force to balance the external load P. At support C, there will be a vertical reaction force and a moment reaction to resist the rotation caused by the external load.
In order to find the deflection 'del' under the load P, we need to solve the equations of equilibrium for the entire beam, taking into account the moment release at B. This can be done by considering the two separate members of the compound beam and their individual moments and reactions at the pin connection.
Finally, it is important to note that the moment at the pin connection should be zero, as you correctly stated. This is because the pin allows for free rotation, and therefore, the moment at that point will be zero. It is also important to consider the direction of the moments, as they will be equal and opposite due to the moment release condition.
Overall, treating moment release in FBD requires careful consideration of the reactions and moments at each support point, as well as the individual moments and reactions at the pin connection. By properly solving the equations of equilibrium, we can determine the deflection 'del' under the given load P.
FAQ: How to treat moment release in FBD
How do I determine the moment release in a free body diagram (FBD)?
The moment release in a FBD can be determined by summing the moments of all the external forces acting on the body. This can be done using the equation: ΣM = 0. The resulting value will be the moment release.
What is the significance of treating moment release in a FBD?
Moment release is important in FBDs as it helps to accurately represent the forces acting on a body. It allows for a more detailed analysis of the forces and their effects, particularly when dealing with rotational motion.
How does moment release affect the equilibrium of a body in a FBD?
Moment release is necessary for a body to be in rotational equilibrium, in addition to translational equilibrium. If the sum of all the external forces and moments acting on the body is equal to zero, the body will be in equilibrium and there will be no net movement.
Are there different methods for treating moment release in a FBD?
Yes, there are different methods for treating moment release in a FBD, such as the method of joints and the method of sections. These methods involve breaking down the FBD into smaller components and analyzing the forces and moments acting on each component to determine the overall moment release.
How can I ensure the accuracy of moment release in a FBD analysis?
To ensure accuracy in moment release calculations, it is important to carefully consider all the forces and moments acting on the body and to use the appropriate equations and methods for analysis. Double checking calculations and using multiple methods for verification can also help to ensure accuracy.
