How to understand linear momentum?
In summary: It would be interesting to know how the two bodies would compare if they were both moving at the same speed.
Javier Mont
I understand for linear momentum the measure of the dificulty to take a body to the rest. But when I do the next exercises, I find that it requires less force for one body compared to the other with same linear momentum.
Can someone explain me what to understand in an intuitive way what to expect when I see a certain magnitud of linear momentum from a body?
Hello Javier, :welcome:
Actually, PF culture asks you post questions like this in the homework forums. Never mind, I'll ask a mentor.
<Moderator's note: thread moved>
Can you check how long it takes for the two bodies to come to rest ? That's where a difference between the two cases comes in !
A line of thought that may help you:
Acceleration is the time derivative of velocity : ##\vec a = {d\vec v\over dt}##. For a body of a given mass m, multiply this equation with m: $$m\vec a = m {d\vec v\over dt}$$On the left you have (according to Newton) ##\vec F## and on the right there is ##d\vec p\over dt## (since m is a constant) and you get $$\vec F ={ d\vec p\over dt}$$.
Now the cases in your picture: both bodies come to rest over a distance of 0.5 m and you calculate the force needed to achieve this (assuming it is constant). So you compare the products ##\ F\ d\ \ ##. This product has the dimension of energy and in fact you compare the kinetic energies of the two bodies. Kinetic energy is ##{1\over 2}mv^2## so it's no wonder you results differ by a factor of 50 !
If you calculate the forces needed to stop the two bodies in the same time instead of over the same distance , the result may be more to your liking...:smile:
Likes Javier Mont
BvU said:
Now the cases in your picture: both bodies come to rest over a distance of 0.5 m and you calculate the force needed to achieve this (assuming it is constant). So you compare the products F d F d \ F\ d\ \ . This product has the dimension of energy and in fact you compare the kinetic energies of the two bodies. Kinetic energy is 12mv212mv2{1\over 2}mv^2 so it's no wonder you results differ by a factor of 50 !
Yes. It is important to realize the difference between Kinetic Energy and Momentum. Early Science failed to distinguish between the two and had a lot of problems of the sort that the OP quotes.
Likes Javier Mont
Thank you very much! You´re right! That difficult to take a body to rest (linear momentum) is the Force*time, no Force*distance. Thanks!
Interesting
FAQ: How to understand linear momentum?
What is linear momentum?
Linear momentum is a fundamental concept in physics that describes the motion of an object. It is defined as the product of an object's mass and its velocity. In simpler terms, it is the measure of how much an object is moving and in what direction.
How is linear momentum related to Newton's laws of motion?
Linear momentum is closely linked to Newton's laws of motion. In fact, it is often referred to as the "quantity of motion" in Newton's second law, which states that the force applied to an object is equal to the rate of change of its momentum. Additionally, Newton's third law, which states that every action has an equal and opposite reaction, can also be explained in terms of linear momentum.
What factors affect an object's linear momentum?
There are two main factors that affect an object's linear momentum: its mass and its velocity. The greater the mass of an object, the greater its momentum. Similarly, the greater the velocity of an object, the greater its momentum.
How is linear momentum conserved in a closed system?
According to the law of conservation of momentum, the total linear momentum of a closed system (where there are no external forces acting on the system) remains constant. This means that if one object in the system gains momentum, another object must lose an equal amount of momentum in the opposite direction. This principle can be seen in action in collisions, where the total momentum of the objects before and after the collision remains the same.
How can we use linear momentum to solve problems in physics?
Linear momentum is a useful tool for solving problems in physics, particularly those involving motion and collisions. By applying the principles of conservation of momentum and Newton's laws of motion, we can determine the behavior of objects and predict the outcomes of various scenarios. This can be helpful in fields such as engineering, mechanics, and astrophysics.
