How to understand tension force existing in slack side of belt drive?
In summary, the tension on the slack side is due to the belt's friction with the pulleys. This tension is necessary in order to keep the belt moving.
k.udhay
160
Hi,
For a long time, it is always unclear for me to understand that there is a tension force acting in the slack side of a belt drive. Tension acting in the tight side is quite straight forward and hence no doubt!
When I see a belt drive in motion, I always see the slack side kind of deformed and wobbling. This leaves me an impression that there is no force on that portion of belt. But in all our textbooks it is said that there is a tension acting. Can you explain the easiest way to understand this? May be with some examples or videos? Thanks.
The "slack" side is not slack - even if the pulleys are not turning, there is a tension there. Hook one roller/pulley/end/whatever to a spring and you'd see the spring extend under the force. The tension is provided by gravity. The belt looks saggy for the same reason a power line does.
When the pulleys turn, you'll see the "slack" side tighten up a bit compared with rest - showing you the acceleration adds some extra tension there. Clearly the tension in the top has to pull on the bottom just as hard, otherwise the belt would stretch.
Thanks, Simon. Is it something like, the belt is wound / installed with a pre-tension around the pulleys already and this is the slack side tension?
The tension wheel supplies an extra component to the tension - useful for stopping the belts slipping.
Likes 1 person
Thanks, Simon. I think I have to think a little more about what you said to understand clearly. Thanks again! :)
Hi Simson! I exactly caught what you meant! If there is no tension in the slack side, then there will be no friction existing between pulley and belt and hence no motion transfer. Thank you so much!
what causes slack side and tight side is the difference in tension induced due to friction between the pulley and belt. If pulleys are rotating in clockwise direction, relative motion is anticlockwise for belt. hence friction will be in clockwise direction where ever is considered on belt. so belt above pulleys will have higher tension, hence belt below pulleys form slack side and they sag due to self weight.
Think of the belt's two sides as two springs.
At rest they are both stretched equally.
When rotating their tension is unequal by the amount of load being transferred.
The loose side has a lower natural frequency because it's not stretched so tight - so it'll flop around more visibly, like a guitar string..
If the slack side becomes very loose the belt will slip at high load.
This used to happen a lot back when cars used vee-belts.
The alternator belt would become loose through stretch or wear, alternator could no longer keep up with headlights so you'd run the battery down on a long drive after dark. Yet its voltage would check fine in daytime.
A lot of folks bought new battery, alternator & regulator when they just needed the belt tightened.
This also tended to show up at start of summer when airconditioner gets switched on.
hope this helps.
Figure belt tension for tight and slack side (T1 & T2)
force = power/velocity
Assuming you have an motor of 2 hp (1492 N-m/s) and the belt is moving at 12 mph (5.3645 m/s). Metric units are better here so ...
F = (1492 / 5.3645) = 278 Newton (62 pound force - lbf)
So now
T1 = 278 * (1 + (1/(2.7182 * 0.25 * 0.5934))) = 967.4072 Newton (217 lbf)
T2 = 278 * (1/(2.7182 * 0.25 * 0.5934)) = 689.4072 Newton (155 lbf)
P = (967.4072-689.4072) * 5.3645 = 1491.331 N-m/s
It appears the proof works because 1491.331 N-m/s = 1.999 hp (close enough)
u = coefficient of friction is a tough one, but 0.25 for a dry running belt is a good base
a = find out your pulley groove angle, convert to radians (i'm using 34 deg = 0.5934 radians)
Assuming I didn't screw things up, it appears the slack side, in this case, is 71% of the tight side. So it's fairly tight even on the slack side.
1. Just figure what horsepower your motor has (convert hp to N-m/s)
2. How fast the belt is moving (mph to m/s)
Thank you all. All the replies helped me to understand this by different ways. Thanks again!
jryer, in your formula, what is the 2.7182? Do you have a reference to the original formula that you could supply? Thank you!
F = Moving force in the pulley driver
T1 = tension on the tight side
T2 = tension on the slack side
e = base of the Neperian or natural logarithms (2.7182)
μ = coefficient of friction
α = angle subtended by contact surface at the center of the pulley
T1 = F * (1 + (1/(e^ua - 1)))
T2 = F * (1/(e^ua - 1))
@kem0022: welcome to PF;
... jryer (basically) just started with a free-body diagram for the pulleys and followed the math from there.
... you should be moving away from memorizing equations to understanding the processes required to get those equations in the first place, but you know that right?
Compression of slack side
I understand the tightening of "slack side" of the belt when the pulley is being driven. But if the tension on the slack side(bottom as u have referred) was not the same and if it were lesser than the top then wouldn't the slack side compress? how does it stretch? Please share your knowledge Simon.
Welcome to PF;
Looks like you should make a pulley system using a very stretchy rubber band and turn the wheels and watch.
The tight and slack side go at the same speed so there is no compression.
Try doing the free-body diagram to see how the tensions balance out.
Simon Bridge said:
Welcome to PF;
Thanks Mr. Simon. I did happen to study the free body diagram.
I found out that initially when the pulley is stationary, there is a tension force which is nothing but pre tension which is required to generate friction to make the belt and thereby the pulley to move.
Now, when the driving pulley starts rotates there is an increase in tension on one side and decrease in tension(depends on the pre tension). The side with the increased tension is the tight side and the side with lesser tension happens to be the slack side. This tension is also a function of coefficient of friction. Higher the coeff friction, higher is the power transmission capability. Hence we have difference in tension which acts as the driving force of the belt. Thus the belt rotates at almost the velocity of pulley(there will be belt slip). This causes the driven pulley to rotate and hence power is transmitted.
As i pointed out in my earlier reply, there will be contraction and expansion in the belt Mr. Simon. They call it the phenomenon of elastic creep. It is nothing but, in the driving pulley, the area of belt under the tight side of pulley will undergo elongation and the area of belt above the slack side of the pulley will undergo contraction.
So yeah. Thats it. Thanks Mr. Simon.
Related to How to understand tension force existing in slack side of belt drive?
1. What is tension force in a slack side of belt drive?
Tension force refers to the force applied to a belt in order to keep it tight and prevent it from slipping or losing contact with the pulleys. In a slack side of a belt drive, tension force is necessary to maintain the proper tension on the belt and ensure efficient power transmission.
2. How is tension force calculated in a slack side of belt drive?
Tension force in a slack side of belt drive can be calculated using the formula T = (μ x W x e)/R, where T is the tension force, μ is the coefficient of friction, W is the weight of the belt, e is the distance between the center of the pulleys, and R is the radius of the pulleys.
3. What factors affect tension force in a slack side of belt drive?
There are several factors that can affect tension force in a slack side of belt drive, including the coefficient of friction between the belt and pulleys, the weight of the belt, the distance between the pulleys, and the radius of the pulleys. Other factors such as belt material, speed, and tensioning methods can also play a role.
4. How can tension force be adjusted in a slack side of belt drive?
Tension force in a slack side of belt drive can be adjusted by changing the position of the pulleys, using different tensioning methods such as tensioners or idlers, or by changing the belt material or type. It is important to ensure that the tension force is within the recommended range for the specific belt drive system.
5. What are the consequences of incorrect tension force in a slack side of belt drive?
If tension force in a slack side of belt drive is too low, the belt may slip, resulting in reduced power transmission and potential damage to the belt and pulleys. On the other hand, if tension force is too high, it can put excess strain on the belt and pulleys, leading to premature wear and failure. It is important to carefully monitor and maintain the correct tension force in order to ensure optimal performance and longevity of the belt drive system.
  • Mechanical Engineering
