How to use formulas for a delta wing?
The discussion centers on the calculations of lift force in aerodynamic formulas, specifically addressing the challenges posed by delta wing aircraft that lack a traditional horizontal tail. Participants highlight the importance of the center of mass and center of lift being closely aligned for stability. It is noted that delta wings utilize a built-in reflex to provide negative lift, compensating for inherent pitch moments. The conversation also references external resources for further understanding of these aerodynamic principles. Overall, the complexities of lift calculations for delta wings are emphasized, particularly in the absence of a horizontal tail.
kevcrl
Dear Forum,
I'd like to talk about the formulas about aerodynamic calculations.
Let's focus on the lift force.
As you may know, the lift force is computed as
The CL coefficient can be decomposed with a Taylor serie which is
Now, each coefficient can be rewritten in detail as:
As we can see, there is a ratio of of the horizontal surface tail to the wing surface Sh/S
However, how has this parameter to be used in case of a delta wing aircraft with no horizontal tail
Shall we do consider the Sh surface as zero ?
Thanks
Welcome, @kevcrl !
Delta wings, like any other tailless airplane that needs longitudinal stability, have a built-in tail, which is called reflex.
That works exactly like the horizontal stabilizer of conventional airplanes, providing negative lift to compensate for the natural pitch (nose down) moment that the pressure gradient induces in any airfoil.
Please, see:
https://mh-aerotools.de/airfoils/flywing1.htm
:cool:
Likes Klystron and Baluncore
Very good website thank you very much :)
Likes berkeman and Lnewqban
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
Thread 'SpaceX Starship development: 7th flight January 10'
Watch the progress live This is a fully stacked Starship (top) and Super Heavy (bottom). A couple of too-small-to-see cars near the bottom for scale, I also added a Saturn V and the Statue of Liberty for comparison. 120 meters tall, about 5000 tonnes when fully fueled. Twice the mass and over twice the thrust of Saturn V. The largest rocket ever built by mass, thrust, height, and payload capacity. N1 had the largest diameter.[/size] But its size is not the revolutionary part. It is designed...
Venus does not have a magnetosphere, so the Galactic Cosmic Rays (GCRs) environment shall be much worse than in a LEO environment. Looking to the std radiation models for Venus, the standard radiation-hard space level electronic component with tested immunity LET = 85 MeV-cm2/mg seems not enough, so, for example, a 1cm2 Si die will suffer considerable flux above this level during a long mission (10 years for example). So, the question is, usually we are not paying attention to latch-up...
