I How to use geometrical symmetries -- general advice? (Vector potential)
  • I
  • Thread starter Thread starter LeoJakob
    Vector potential
Identifying useful symmetries in vector potential can be challenging, particularly in the context of an infinitely long hollow cylinder carrying current. The vector potential, denoted as ##\vec{A}##, is shown to be independent of ##z## and ##\varphi## due to the cylindrical symmetry of the current and charge densities. This symmetry implies that the magnetic flux density ##\vec{B}## must also be cylindrically symmetric, leading to the conclusion that ##\vec{A}## can be expressed solely as a function of the radial coordinate ##\rho##. While it is not possible to mathematically prove the independence of certain coordinates universally, symmetry arguments provide a strong basis for understanding the behavior of vector fields in this context. Understanding these symmetries is crucial for correctly applying them in calculations involving vector potentials.
LeoJakob
The following is an example from my script. I always have trouble identifying useful symmetries. Can someone explain to me why (for example) the vector potential doesn't have a ##z## dependence? I understand that there is no ##\varphi## dependency.
I don't understand why the field of ##\vec{A}## has to be parallel to the ##z## axis. What about ##d^{3} \overrightarrow{r^{\prime}}##??? Is there a way to show mathematically that the vector potential is independent of the two variables ##z\varphi##?
In general, I have problems identifying symmetries and using them correctly.
Magnetic flux density of an infinitely long hollow cylinder
The hollow cylinder is homogeneously traversed by the current ##I##. Calculate the magnetic flux ##\vec{B}(\vec{r})## as the curl of the vector potential ##\vec{A}(\vec{r})##.
\begin{aligned}
\vec{A}(\vec{r}) & =\frac{\mu_{0}}{4 \pi} \int \limits_{V} \frac{\vec{j}\left(\overrightarrow{r^{\prime}}\right)}{\left|\vec{r}-\overrightarrow{r^{\prime}}\right|} d^{3} \overrightarrow{r^{\prime}} \\
\vec{j}(\vec{r}) & =j \vec{e}_{z}
\end{aligned}
Use cylindrical coordinates ##\vec{r}=(\rho, \varphi, z)##. Due to the symmetry, we have:
\vec{A}(\vec{r})=A(\rho, \varphi, z) \vec{e}_{z}=A(\rho) \vec{e}_{z}
If you have an infinitely long cylindrical object then the field can't depend on either ##z## or ##\varphi## because the charge and current densities are symmetrical under rotation around the ##z## axis and translation along it. If the sources are symmetric like that, how can the fields be otherwise? If they were (e.g.) weaker at some ##z=z_0##, why there?
So the ##\vec B## field is cylindrically symmetric. What ways can a vector field be cylindrically symmetric? What does that tell you about ##\vec A##?
There is no way to generally prove that the vector potential does not depend on particular coordinates since it is always possible to perform a gauge transformation ##\vec A \to \vec A + \nabla \phi## with the same resulting field for any scalar function ##\phi##.
Any symmetry argument must be based on this particular expression for the vector potential.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
