How to view conditional variance intuitively?
This result can also be derived using the formula for the conditional variance, ##v_x(Q) = 1 - \frac{\int_Q \phi(x) dx}{\phi(0)}##, where ##\phi(x)## is the standard normal density function. Since ##g(x) = 2 \frac{1}{\sqrt{2 \pi}} \phi(x)##, we have ##v_x(Q) = 1 - \frac{2}{\pi} \frac{\int_Q \phi(x) dx}{\int_{-\infty}^{\infty} \phi(x) dx} = 1 - \frac{2}{\pi} \frac{\int_Q \phi(x
yamata1
61
We have a sample of X, a Normalized Gaussian random variable.We divide the data into positive and negative.
Each will have a conditional variance of ## 1−\frac{2}{π}## .
Can someone show how to get this result ?
I found this problem here (page 3) : https://www.dropbox.com/s/18pjy7gmz0hl6q7/Correlation.pdf?dl=0
Thank you.
The title of the thread speaks of viewing something intuitively but your question
seems ask for a mathematical derivation.
The relevant passage in the document concerns forming a correct intuition about conditional variances - the correct intuition being that they need not be larger (or smaller) than the variance of the original distribution that is constrained.
The problem becomes much easier when we consider the behavior in lower dimensions for Gaussian variables. The intuition is as follows. Take a sample of X, a Normalized Gaussian random variable. Verify that the variance is 1. Divide the data into positive and negative. Each will have a conditional variance of 1−2/π=≈0.363. Divide the segments further, and there will be additional drop in variance. And, although one is programmed to think that the tail should be more volatile, it isn’t so; the segments in the tail have an increasingly lower variance as one gets further away, see in Fig.4.
I am failing to understand the way to get this answer . Is there a simple computation or property that easily gives this answer ? I tried the formula for ##v_x(Q)## without success.
Consider the case when the random variable ##X## has a probability density given by ##g(x) = 2 \frac{1}{\sqrt{2 \pi} } e^{-{x^2/2}}## for ##x \ge 0##.
The variance of ##X## is ##\sigma^2_X = \int_0^\infty x^2 g(x) dx -( \int_0^{\infty} x g(x) dx)^2##
##\int_0^\infty x^2 g(x) dx = \int_0^\infty x^2 2 \frac{1}{\sqrt{2 \pi}} e^{-{x^2/2}} dx##
## = 2 \int_0^\infty x^2 \frac{1}{\sqrt{2 \pi}} e^{-{x^2/2}} dx ##
##= \int_{-\infty}^{\infty} x^2 \frac{1}{\sqrt{2 \pi}} e^{-{x^2/2}} dx = 1##
since the last integral is the same as computing the variance of a normal distribution that has mean zero and variance 1.
##\int_0^\infty x g(x) dx = \int_0^\infty x (2 \frac{1}{\sqrt{2 \pi}} e^{-{x^2/2}}) dx##
## = ( -2 \frac{1}{\sqrt{2 \pi}} e^{-{x^2/2}}) |_0^\infty ##
##= 0 - ( -2 \frac{1}{\sqrt{2 \pi}})##
## = \frac{\sqrt{2}}{\sqrt{\pi}}##
So ##\sigma^2_X = 1 - (\frac{\sqrt{2}}{\sqrt{\pi}})^2 = 1 - 2/\pi##
Likes zinq, yamata1 and FactChecker
Related to How to view conditional variance intuitively?
1. What is conditional variance?
Conditional variance is a statistical measure that quantifies the amount of variability in a set of data, given a specific condition or set of conditions. It is typically used to understand how the variance of a dependent variable changes in response to changes in an independent variable.
2. How is conditional variance different from regular variance?
Regular variance measures the overall variability in a set of data, while conditional variance specifically measures the variability of a dependent variable under certain conditions. In other words, conditional variance takes into account the relationship between two variables, while regular variance does not.
3. How can I intuitively understand conditional variance?
One way to intuitively understand conditional variance is to think of it as a measure of how much a dependent variable changes in response to changes in an independent variable. For example, if we are looking at the relationship between temperature and ice cream sales, conditional variance would tell us how much ice cream sales vary for every degree change in temperature.
4. What are some common applications of conditional variance?
Conditional variance is commonly used in fields such as economics, finance, and statistics to understand the relationship between variables and make predictions. It can also be used in experimental research to measure the effect of an independent variable on a dependent variable.
5. How is conditional variance calculated?
Conditional variance is typically calculated using statistical software or formulas. One common formula is the conditional variance formula for a linear regression model, which involves taking the sum of the squared differences between the actual and predicted values of the dependent variable, divided by the number of observations minus the number of independent variables.
