How to write 100 and -100 in phasor notaion
  • Thread starter eatsleep
  • Tags
    Phasor
In summary, the given signals can be represented in phasor notation as v7(t) = 100V ∠ 0° and v8(t) = 100V ∠ 180°. The equation Acos(wt + Θ) can also be written as Ae^(jθ). Phasors are only applicable for steady-state sinusoids, and the values given in the conversation may need to be converted to RMS values if they are peak values.
eatsleep
42
1. Write the following signals in phasor notation: v7(t)=100, v8(t)=-100(
2. Acos(wt + Θ) = Ae^(j Θ)
3. I want to say 0 because its just a constant, if not then 1 because Θ=0. It seems to easy. Is it 0?
If it's an AC voltage with 0° phase shift, then the 100V source is just 100V ∠ 0°. The -100V source can be written as -100V, or alternatively, 100V ∠180°. Often, when the angle is 0 or 180 the shorthand 100V or -100V is adequate, so long as you make sure to specify clearly that it's a phasor value.
EDIT: As rude man points out in his (the next) post, phasor magnitudes are generally taken to be RMS values. If your given values of 100 and -100 are peak values of the sinusoid, then convert to RMS.
If a voltage in the time domain is v(t) = v0 sin(wt + θ) then the phasor is
V = (v0/√2)e.
So your equation 2 is off by a factor √2 and in 3 if the voltages are dc then there is no phasor at all since there is no sinusoidal voltage.
Phasors are applicable only for steady-state sinusoids.
If v7 = 100 sin(wt) or -100sin(wt) then the above should provide you your answers.
FAQ: How to write 100 and -100 in phasor notaion
How do I write 100 in phasor notation?
To write 100 in phasor notation, you would use the formula A∠θ, where A represents the magnitude and θ represents the angle. In this case, A would be equal to 100 and θ would be equal to 0 degrees.
How do I write -100 in phasor notation?
To write -100 in phasor notation, you would use the same formula A∠θ, where A represents the magnitude and θ represents the angle. However, in this case, A would be equal to 100 and θ would be equal to 180 degrees.
Can I use phasor notation for negative values?
Yes, phasor notation can be used for both positive and negative values. The magnitude and angle will just be different depending on whether the value is positive or negative.
What is the purpose of using phasor notation?
Phasor notation is commonly used in electrical engineering to represent the amplitude and phase of an alternating current or voltage. It allows for complex numbers to be represented in a simpler and more visual format, making calculations and analysis easier.
How is phasor notation related to complex numbers?
Phasor notation is a way to represent complex numbers in polar form, where the magnitude is represented by the length of the vector and the angle is represented by the direction of the vector. This allows for easier visualization and analysis of complex numbers in electrical engineering applications.
