MHB How to write the quadratic function.
To write a quadratic function with a maximum value of 4 and an axis of symmetry at x = -2, the vertex form of the function is used: y(x) = a(x - h)² + k, where the vertex is at (h, k). The vertex should be at (-2, 4) since the maximum occurs there. The coefficient 'a' must be negative to ensure the parabola opens downwards, indicating a maximum point. Thus, the function can be expressed as y(x) = -a(x + 2)² + 4, with a > 0. This formulation meets the specified criteria for the quadratic function.
mathlearn
Write a quadratic function y whose maximum value is 4 and the axis of symmetry of the graph is x=-2.
Suggestions?
Mathematics news on Phys.org
Where should the vertex be? Recall the vertex form of a quadratic may be written as:
$$y(x)=a(x-h)^2+k$$
where the vertex is at $(h,k)$. Since the quadratic is to have a maximum, what can we say about $a$?
$$y(x)=a(x-h)^2+k$$
Since the quadratic is to have a maximum , 'a' should be a negative.
$$y(x)=-a(x+2)^2+4$$
Correct?
Correct?
Yes, as long as $0<a$, then you have correctly given the family of quadratics that meet the stated criteria. :D
Alternately, you could state:
$$y(x)=a(x+2)^2+4$$ where $a<0$.
Thank you very much :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
