Graduate How was the symmetry used here? ("QFT and the SM" by Schwartz)
  • Thread starter Thread starter Hill
The discussion centers on the role of symmetry in the derivation of energy-momentum conservation from Noether's theorem. It highlights that the assumption of symmetry is embedded in the Euler-Lagrange (E-L) equations, which require the action to be independent of the field's explicit dependence on spacetime coordinates. Specifically, the transformation's symmetry is crucial in step 3, where the variation of the Lagrangian is shown to be a total derivative, leading to the conclusion that the action remains invariant under translations. Participants emphasize the subtleties involved in understanding these concepts, noting that many textbooks fail to adequately address them. The conversation underscores the importance of recognizing how symmetries influence the formulation of physical laws in quantum field theory.
Hill
TL;DR
In this derivation of energy-momentum conservation, on what step the symmetry of space-time translation was used?
Here are steps.
Consider shift of field ##\phi## by a constant 4-vector ##\xi##:
(1) ##\phi(x) \rightarrow \phi(x+\xi)=\phi(x)+\xi^{\nu} \partial_{\nu} \phi(x) + ... ##
The infinitesimal transformation,
(2) ##\frac {\delta \phi} {\delta \xi^{\nu}} = \partial_{\nu} \phi##
and
(3) ##\frac {\delta \mathcal L} {\delta \xi^{\nu}} = \partial_{\nu} \mathcal L##
Using the E-L equations, the variation of Lagrangian is
(4) ##\frac {\delta \mathcal L[\phi, \partial_{\mu} \phi]} {\delta \xi^{\nu}}=\partial_{\mu} (\frac {\partial \mathcal L}{\partial (\partial_{\mu} \phi)} \frac {\delta \phi} {\delta \xi^{\nu}})##
Using (2) and (3),
(5) ##\partial_{\nu} \mathcal L =\partial_{\mu} (\frac {\partial \mathcal L}{\partial (\partial_{\mu} \phi)} \partial_{\nu} \phi)##
or equivalently
(6) ##\partial_{\mu} (\frac {\partial \mathcal L}{\partial (\partial_{\mu} \phi)} \partial_{\nu} \phi - g_{\mu \nu} \mathcal L) = 0##
The conclusion is,
"The four symmetries have produced four Noether currents, one for each ##\nu##:
##\mathcal T_{\mu \nu} = \frac {\partial \mathcal L}{\partial (\partial_{\mu} \phi)} \partial_{\nu} \phi - g_{\mu \nu} \mathcal L##
all of which are conserved: ##\partial_{\mu} \mathcal T_{\mu \nu}=0##."
My question: where in this derivation the assumption was used that the transformation is a symmetry?
Likes haushofer and Demystifier
The assumption of symmetry is hidden in the use of EL equation. If you did not use EL equation, that would mean that ##\phi(x)## is treated as a non-dynamical fixed background, the explicit ##x##-dependence of which would violate the symmetry. Indeed, the EL equation can be written as
$$\frac{\delta A}{\delta \phi(x)}=0$$
where ##A## is the action, which can be interpreted as a statement that you only consider such ##\phi(x)## for which the action does "not depend" on ##\phi(x)##. Since the dependence on ##x## arises only from dependence on ##\phi(x)##, this means that EL equation expresses also independence on ##x##, which is nothing but the symmetry.
Thank you.
I think also that the symmetry validates the equation (3), because this equation makes the variation of Lagrangian a total derivative, and this makes the variation of action vanish: $$\delta A = \int d^4 x \delta \mathcal L = \delta \xi^{\nu} \int d^4x \partial_{\nu} \mathcal L = 0$$ IOW, without the symmetry, we can't go from (4) to (5).
Hill said:
TL;DR Summary: In this derivation of energy-momentum conservation, on what step the symmetry of space-time translation was used?
Here are steps.
and
Using (2) and (3),
or equivalently
The conclusion is,
I believe that the symmetry is used in step 3. Under the translation symmetry the Lagrangian change is a total derivative. I think this is essentially what @Demystifier is saying.
Incidentally, i wrote a long blog post on this derivation but omitted this question. Thanks for bringing it up.
Thank you. That was my understanding also, in the post #3.
Step 3 is just saying the Lagrangian is a scalar (density) under translations, right?
I also find this stuff treacherous, and many textbooks completely miss these subtleties and make it look easy. My confusion for a long time was that these symmetries are derived "on shell", but then EL=0 for any variation of the field. And I know from experience that you can even confuse post docs working on string theory with this stuff.😋
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
  • · Replies 0 ·
  • · Replies 24 ·
