- #36
phyzguy
- 2,256
Using the Leavitt's law formula in this Wikipedia article, I get an absolute magnitude of -5.14.Da_Rex said:Seems I had a error in the distance calculations. For that I used the distance modulus to calculate the distances.
Host Galaxy / Galaxy Cluster Name of Cepheid Variable StarPeriod (days) Apparent Magnitude Absolute Magnitude Red shift (z)[dimensionless] Recessional velocity [Kms-1] Distance (d) [Mpc]I subtracted the apparent magnitude from the absolute magnitude: 27.35 -(-8.154) then I added 5 and divided everything by 5 to get 8.1008. Then I did 10^8.1008 to get the distance in Parces then divided that number by 10^6 to get the distance in Mpc which gave the incorrect value 126.134.
NGC 4603 71 28.00 27.35 -8.1540.008647 2594.1 126.134
The redshift values are also a bit off as I assumed the redshift values of the cepheids to be the same as their host galaxy. This was becuase I was unable to access the redshfit values for the cepheids. This somewhat harmed the recessional velocity I believed.
Previously as a guide I was using this website, https://www.atnf.csiro.au/outreach/education/senior/astrophysics/variable_cepheids.html However the website suddenly stopped working and couldn't be used anymore.
However I believe I found the source of error, which happened to be the value of the b constant in the Leavitts law which I used as 4.16 however after using 1.35 I received a similar value.
