How would water vapor contamination affect PV=nRT
In summary: If it was part of it sticking out of the water, did the water touch the canister at any point?In summary, the student's experiment was trying to determine the value for absolute zero using a canister of CO2 with a pressure sensor. They heated the canister up by placing it in a beaker of boiling water and then slowly cooled the water and took measurements until the temperature reached 0 degrees celsius. They then placed the results in an excel spreadsheet to make a graph of P vs V. Their answer was -302.9 which is obviously off from -273.15. It is possible that water vapor contamination could be the reason for the discrepancy.
skate_nerd
176
Doing a lab here, but were kind of stuck. This lab is meant to experiment the formula PV=nRT, and the set up is a canister of CO^2 with a fixed volume that has a pressure sensor connected to it reading in pascals. We heat up the CO^2 by placing the canister in a beaker of boiling water and then slowly cool the water and take measurements until it reaches 0 degrees celsius. These results were placed in an excel spreadsheet to make a graph of P vs V, and this is used to extrapolate the value for absolute zero in celsius. Our answer was -302.9 which is obviously off from -273.15.
QUESTION:
Suppose the trapped air were contaminated with water vapor. How would this affect the P vs V graph? Do you see any such effect?
PV=nRT
We think the answer is yes and this is our source of the discrepancy, but we aren't sure. If the water vapor did contaminate the air, would that increase n in moles in the formula PV=nRT to make our graph offset too low like it did?
cool experiment. Although, it sounds kind of dangerous to be heating up pressurised canisters?! I guess the teacher knew beforehand that they could take the temperature change which you guys were subjecting them to?
Anyway, yeah, water vapour contamination sounds like a possible reason. It is not just because this would change n though. Think about the equation. Do you trust that the equation is true even if there is water vapour contamination. A hint is in the name of the equation.
Edit: ah, whoops! For some reason I got confused between water droplet contamination and water vapour contamination. I was writing water vapour, while thinking water droplets... Uh, still even with water vapour, it might affect the results. Yeah, your explanation of the water vapour causing a change in n from what you would expect sounds reasonable.
Actually, If we assume that water vapour is still an ideal gas, then would this change your prediction of absolute zero?
Edit: think about the equation, and if n was different, for example, n+m, then would your prediction be different?
QUESTION:
PV=nRT
This description is very confusing. Before we can help you, you need to help us out.
1. You have a canister with CO2 in it. Where did the air come from?
2. The volume of the canister is fixed. Did you plot P vs V, or P vs T?
3. By what physical mechanism would water vapor get into the closed canister?
4. What was the starting pressure of the gas in the canister? At the range of pressures and temperatures involved, is CO2 expected to behave like an ideal gas?
5. Is the measured pressure absolute pressure or gage pressure (relative to the room pressure)?
6. How do you know that the canister was thermally equilibrated with the water bath at each temperature?
7. Was the canister fully submerged, or was part of it sticking out of the water?
I would first want to confirm whether or not the trapped air was indeed contaminated with water vapor. This can be done by conducting a separate experiment to measure the amount of water vapor present in the air inside the canister. If it is found to be contaminated, then it is likely that the water vapor would affect the P vs V graph.
Water vapor contamination would affect the PV=nRT formula in several ways. First, the presence of water vapor would increase the total number of moles (n) in the formula. This is because water vapor is composed of molecules (H2O) that would add to the total number of molecules present in the canister. This increase in n would result in a higher value for pressure (P) at a given volume (V), which would shift the P vs V graph upwards.
Additionally, the presence of water vapor would also affect the ideal gas constant (R) in the formula. This is because the ideal gas constant takes into account the properties of the gas molecules, such as their size and intermolecular forces. Water vapor molecules have different properties than CO2 molecules, and therefore would affect the value of R. This would also result in a shift in the P vs V graph.
In conclusion, water vapor contamination would affect the PV=nRT formula by increasing the value of n and potentially altering the value of R. This would result in a shift in the P vs V graph and could explain the discrepancy in the extrapolated value for absolute zero. Further experiments and analysis would be needed to accurately determine the extent of the effect of water vapor on the PV=nRT formula and the resulting graph.
Related to How would water vapor contamination affect PV=nRT
1. What is PV=nRT and how does it relate to water vapor contamination?
PV=nRT is the ideal gas law, which describes the relationship between pressure (P), volume (V), temperature (T), and number of moles (n) of an ideal gas. Water vapor contamination can affect this equation by changing the amount of water vapor present in the gas mixture, which can alter the pressure and temperature of the gas.
2. How does water vapor contamination affect the pressure in the PV=nRT equation?
Water vapor is considered a non-ideal gas, meaning it does not follow the ideal gas law perfectly. When water vapor is present in a gas mixture, it can increase the overall pressure due to its intermolecular forces with other gas molecules. This can lead to a deviation from the expected pressure calculated using PV=nRT.
3. Can water vapor contamination affect the volume in the PV=nRT equation?
Yes, water vapor can also affect the volume in the PV=nRT equation. Water vapor molecules take up space in the gas mixture, reducing the available volume for other gas molecules. This can lead to a decrease in volume and a deviation from the expected value calculated using PV=nRT.
4. How does the presence of water vapor affect the temperature in the PV=nRT equation?
Water vapor has a lower specific heat capacity than most gases, meaning it requires less energy to raise its temperature. When water vapor is present in a gas mixture, it can absorb some of the heat energy, reducing the overall temperature of the gas. This can lead to a deviation from the expected temperature calculated using PV=nRT.
5. Can water vapor contamination affect the number of moles in the PV=nRT equation?
Yes, water vapor can affect the number of moles in the PV=nRT equation. Since water vapor is considered a gas, it is included in the number of moles (n) in the equation. If the amount of water vapor changes in the gas mixture, it will also affect the number of moles and can lead to a deviation from the expected value calculated using PV=nRT.
12K
  • Biology and Medical
22K
12K
108K
