How would we measure time and location in space?
In summary, the conversation is discussing the hypothetical situation of aliens encountering humans in the future, and the need for a common measure of location and time.
adimantium
Let us all pretend it 150 years in the future and we all have spaceships and can travel through space easily without disrupting time.
Our only measure of location would be compared to Earth, and our measure of time would be Earth time (revolutions around the sun and rotations). What if we come across some friendly aliens and we want to communicate with them. There home planet would have a longer or shorter year and they would not compare there location to our earth. So we and all our alien friends would need a constant location that would never move. I think the center of the universe (place of the big bang) would be a good place. However if we were going to make a 3D plane with the origin at the center of the universe, we would need 3 noncollinear points to mark such plane. We would need a unit of time also. I think we could use a hydrogen atom. We could multiply the diameter by a few billion, and we have an extremely precise measurement of distance. We would also need a constant in time. but we would need two points to mark a line. The first point would probably be the origin of the universe in time (the time of the big bang). The other point could be a unit of time. We could say it is 4 billion or so years from the beginning of space, however our alien friends have a different year than us. So we need another constant in time. I think we would use the speed of light and a distance to do this. Light will always take the same amount of time to go X distance, therefore we need a constant distance. Again we could use a hydrogen atom(multiplied by a few billion of course) and see how long it takes light to go that far, and multiply that by a hundred or so, and then we have constant unit of time to compare to the beginning of the universe.
So, can you come up with anything better for a unit of time or distance? Also we still need two more points noncollinear points compared to the center of the universe.
P.S. Thank you for reading that if you did. : )
Astronomy news on Phys.org
Note that the Big bang didn't happen in one place. It happened everywhere
The big bang happened everyware
Yes, but didn't it start in one place?
Emphatically not. You need to study some basic cosmology.
I recommend the link in my signature as a place to start.
Your question indicates some misunderstandings of space and time. They are not independent of each other. As phinds says, you need to study more cosmology, or at least some basic relativity. Before the Big Bang, there was no place, or time.
Related to How would we measure time and location in space?
1. How do we measure time in space?
Time in space is measured using atomic clocks, which are highly accurate and precise. These clocks use the vibrations of atoms to keep time, rather than relying on the rotation or orbit of celestial bodies. This allows for consistent timekeeping regardless of the location in space.
2. Can we use traditional clocks to measure time in space?
No, traditional clocks such as mechanical or digital clocks would not be accurate in measuring time in space. This is because they are designed to keep time based on Earth's rotation and orbit, which would not apply in the vastness of space.
3. How do we measure location in space?
Location in space is measured using a coordinate system called celestial coordinates. This system is similar to latitude and longitude on Earth, but uses different reference points such as stars and galaxies. It allows for precise tracking and navigation in space.
4. Do we use GPS to measure location in space?
No, GPS (Global Positioning System) relies on a network of satellites in Earth's orbit and would not work in the same way in deep space. Instead, spacecrafts use a combination of celestial coordinates and other instruments to determine their location in space.
5. How does the measurement of time and location in space affect space travel?
Accurate measurement of time and location in space is crucial for successful space travel. It allows for precise navigation and communication, as well as ensuring that spacecrafts reach their intended destinations. It also helps with scientific research and exploration of the universe.
