How would you solve a momentum problem including friction and/or springs?
In summary: , in summary, you would need to do a regular collision problem to find the velocities of each car after the collision.
spectravoid
how would u implement kinetic friction and springs into a momentum question?
None of the questions in my textbook shows a momentum+friction/springs question
lets say
Car A (350 kg) is traveling 60 m/s east and car B (400 kg) is traveling 30 m/s west. The collision is completely elastic. The coefficient of kinetic friction on the road is 0.45 (assume its not rolling friction). The cars make an eventual stop. What is the total distance traveled by cars A and B after the collision. And let's say part 2 is what if the collision was inelastic, what would the answer then be?
and let's have another question.
A 1 kg cart is moving 4 m/s east and then runs into a spring on the side of a wall. The spring's constant is 1000 N/m. the spring gets compressed 0.6 m. The cart gets pushed back west and hits a 0.5 kg cart at rest. What is the velocity of the cart that was still if it was an elastic collision? And what would the velocity be if it was an inelastic collision
i just make up the problems
well for elastic collisions since energy is conserved
i just assumed you first do
m1v1i + m2v2i = m1v1f + m2v2f and
Wnc + KEit = KEft
(non conservative work + total initial kinetic energy) = final kinetic energy
but i have no clue how to do one that is inelastic
Are you saying that you made up these problems?
yes i did why?
WIth your first question, I assume the velocities are right before the colission and friction occours only after colission. FIrst off, it the colission is inelastic, the cars don't stick together. I would
!. Do a reagular colission problem to find velocities of each car aftger the colission.
2. Friction is a constant force. Now, you can find distance traveled using kinematics equations.
spectravoid said:
yes i did why?
Because the problem might be lacking sufficient information to solve. For example: question 1 part 2 (the inelastic version). By looking at the problem inelastically, you have eliminated one equation, namely conservation of KE. But you will still have two unknowns--the final velocities of the two objects.
This can be handled in two ways: Assume that the two bodies "stick" and therefore there is only one final velocity of the mass (m1+m2).
Or if you are given the coefficient of restitution or COR, you can solve for the final velocities. Check the wikipidia definition of COR, it's pretty short and sweet-->http://en.wikipedia.org/wiki/Coefficient_of_restitution" .
Then you could find out the final KE of each car and use conservation of energy to find the distance each car skids.
Or as flatmaster said you could use kinematics. However, if you have learned conservation of energy, I suggest you try that method too as it is a simpler calculation. I would actually suggest that you take the extra five minutes to do it both ways as that will deepen your understanding of the subject.
Casey
Related to How would you solve a momentum problem including friction and/or springs?
1. How do you calculate the net force in a momentum problem involving friction?
In order to calculate the net force, you must first determine the individual forces acting on the object. This includes the force of friction, which can be calculated by multiplying the coefficient of friction by the normal force. Once all forces have been identified, you can use the equation Fnet = ma to find the net force.
2. How does friction affect momentum?
Friction acts as a resistive force, meaning it opposes the motion of an object. This means that friction will decrease the momentum of an object by reducing its speed or causing it to come to a complete stop.
3. How do you incorporate springs into a momentum problem?
Incorporating springs into a momentum problem requires you to consider the elastic potential energy of the spring. This energy can be calculated using the equation PE = 1/2kx^2, where k is the spring constant and x is the displacement of the spring. This potential energy can then be converted into kinetic energy, which can be used to solve for the final velocity of the object.
4. What is the relationship between momentum and velocity?
Momentum and velocity are directly proportional, meaning that an increase in velocity will result in an increase in momentum. This relationship can be expressed mathematically as p = mv, where p is momentum, m is mass, and v is velocity.
5. How do you approach a momentum problem that involves multiple objects?
When dealing with multiple objects in a momentum problem, it is important to consider the conservation of momentum. This means that the total momentum of the system before and after the interaction between the objects will remain constant. You can use this principle to set up an equation and solve for the unknown velocities of the objects.
