Hubble finds universe may be expanding faster than expected
In summary, a recent study using the Hubble Space Telescope has shown that the universe may be expanding faster than previously thought, by 5 to 9 percent. This surprising finding could provide important insights into the mysterious dark energy, dark matter, and dark radiation that make up 95 percent of the universe. The study used 300 supernovae and Cepheid variables to determine cosmological distances, but there is a potential flaw in this method as it does not take into account the possibility of SNe Iax, which have a similar light curve but are much dimmer than SNe Ia. This could lead to misclassification and errors in determining the rate of expansion.
|Glitch|
429
117
Astronomers using NASA's Hubble Space Telescope have discovered that the universe is expanding 5 percent to 9 percent faster than expected.
"This surprising finding may be an important clue to understanding those mysterious parts of the universe that make up 95 percent of everything and don't emit light, such as dark energy, dark matter, and dark radiation," said study leader and Nobel Laureate Adam Riess of the Space Telescope Science Institute and The Johns Hopkins University, both in Baltimore, Maryland.
The results will appear in an upcoming issue of The Astrophysical Journal.
Source:
http://phys.org/news/2016-06-hubble-universe-faster.html
According to the paper they used 300 SNe Ia along with Cepheid variables, as a basis for determining cosmological distances. With the exception of 19 SNe Ia, which were calibrated using nearby Cepheids, the remaining 281 SNe Ia were based purely on their light curve to determine their type. There is a fundamental problem with this methodology, when it is the only basis used to determine the type of a SNe. It is not always accurate. SNe Iax have the exact same light curve, including the lack of hydrogen in its spectrum as SNe Ia, except that they are several orders of magnitude dimmer than SNe Ia.
All SNe Ia have an absolute magnitude of -19.3, which is why they are used as a "standard candle." However, unless one also looks at other factors, such as the velocity of the ejecta, you cannot rule out the possibility of a SNe Iax, which could have an absolute magnitude anywhere from -14.2 to -18.9. All SNe Ia have ejecta with velocities that equal or exceed 10,000 km/s, whereas all SNe Iax ejecta velocities are less than 8,000 km/s. But if you only look at the light curve of the SNe, then there is no way to be certain if it is actually a SNe Ia. It is estimated that anywhere from 18% to 48% of all the SNe Ia have been misclassified and should actually be the much dimmer SNe Iax. That is a significant margin for error, and would have a profound effect determining the rate of expansion.
Sources:
A 2.4% Determination of the Local Value of the Hubble Constant - arXiv 1604.01424
Type Iax Supernovae: A New Class of Stellar Explosion - The Astrophysical Journal, Volume 767, Number 1, March 25, 2013 (free issue)
Likes Fervent Freyja, DennisN, Bandersnatch and 1 other person
Astronomy news on Phys.org
I was about to post about this here in the forum, but you beat me to it, Glitch! :smile:
Related to Hubble finds universe may be expanding faster than expected
1. What is the Hubble Space Telescope?
The Hubble Space Telescope is a powerful telescope that orbits the Earth and captures high-resolution images of objects in space.
2. How does the Hubble Telescope measure the expansion of the universe?
The Hubble Telescope measures the expansion of the universe by using a special instrument called a spectroscope to analyze the light from distant galaxies. By measuring the shift in the wavelength of this light, scientists can determine the speed at which these galaxies are moving away from us.
3. What does it mean that the universe is expanding faster than expected?
This means that the rate of expansion of the universe, known as the Hubble Constant, is larger than previously thought. This indicates that the universe is expanding at a faster rate, which could have significant implications for our understanding of the origin and evolution of the universe.
4. What could be causing the universe to expand faster than expected?
There are a few potential theories for this unexpected rate of expansion. One possibility is the existence of an unknown form of energy, referred to as "dark energy," which is thought to make up a majority of the universe's energy density. Another theory is that there may be variations in the density of matter throughout the universe, causing different regions to expand at different rates.
5. How does this discovery impact our current understanding of the universe?
This discovery challenges our current understanding of the universe and could lead to new theories and models to explain the expansion. It also highlights the importance of continued research and exploration to further our understanding of the vastness and complexity of the universe.
  • Astronomy and Astrophysics
  • Cosmology
