Hubble flow and velocity addition
In summary: The distance ratio between then and now is 1+z ~ 2.41.The observable universe has a radius of 46.5 Gpc (151.4 Gly) so the most distant galaxy we can see is 1.57% of the way out which is very small.In summary, the radius of the observable universe is 46.5 Gpc (151.4 Gly) and the most distant galaxy we can currently see is 15.18 billion light years away. However, due to the expansion of the universe, the Hubble Constant, and the changing redshifts of galaxies, their relative speeds and distances are constantly changing and cannot be accurately compared using traditional velocity addition formulas. Additionally, the concept of length contraction
Stephanus
1,316
104
Dear PF Forum,
I've been wondering about this thing.
The universe's radius is 46 gly. But a galaxy in 13.8 gly from us cannot be seen because it travels faster than the speed of light.
So is there a galaxy in, say, 30 billions light years away from us?
But before that, I'd like to know about this question below.
According to
https://en.wikipedia.org/wiki/Hubble's_law#Observed_values
Hubble constant is 67.6 km/s per mega parsec as of 13th July 2016 observed by https://en.wikipedia.org/wiki/Sloan_Digital_Sky_Survey
Wow, is it last week?
Now, what I want to know is this.
A. Is it true that a galaxy at ##300000/67.6 = 4437.87 mega parsec## or ##4437.87 * 3.26 = 14467## or 14.467 giga light years away from us travels almost at the speed of light wrt us? Let's call it galaxy A
B. Is it true that a galaxy at ####150000/67.6 = 2218.94 mega parsec## or ##2218.94 * 3.26 = 7233## or 7.233 giga light years away from us travels almost at 0.5c wrt us? Let's call it galaxy B
3. Now relativity velocity addition would tell us that.
##v1=\frac{v3+v2}{1+v3.v2}## or
##v3=\frac{v2-v1}{v1.v2-1}##
Let
v1 = speed of galaxy A = 1 wrt us
v2 = speed of galaxy B = 0.5 wrt us
v3 = speed of galaxy A wrt galaxy B
Now if we put the number into equation.
##v3 = \frac{v2-v1}{v1.v2-1}##
##v3 = \frac{0.5-1}{0.5-1} = 1##
So? The speed of galaxy A wrt B is 1?
So, actually, because length is so contracted, then there's no galaxy at say 20 gly away from us? They are all compacted at around 14.4 giga light years away from us?
Thank you very much.
Space news on Phys.org
Stephanus said:
Is it true that a galaxy at ##300000/67.6 = 4437.87## mega parsec or ##4437.87 * 3.26 = 14467## or 14.467 giga light years away from us travels almost at the speed of light wrt us?
Only if we define "speed" in terms of cosmological coordinates--the rate of change of "distance" in cosmological coordinates with respect to "time" in those coordinates. This "speed" is not the same as a relative speed in SR and does not obey the same rules; for example, it is not limited to the speed of light.
Does not apply in this context. The coordinates in which these "velocities" are defined are not SR inertial coordinates, so you can't use the SR velocity addition formula.
This doesn't apply either, for the same reason as above. You are trying to apply SR in a situation where SR is not applicable.
Likes Stephanus
Stephanus said:
A. Is it true that a galaxy at 300000/67.6=4437.87megaparsec300000/67.6 = 4437.87 mega parsec or 4437.87∗3.26=144674437.87 * 3.26 = 14467 or 14.467 giga light years away from us travels almost at the speed of light wrt us? Let's call it galaxy A
B. Is it true that a galaxy at 150000/67.6 = 2218.94 mega parsecor or 2218.94 * 3.26 = 7233## or 7.233 giga light years away from us travels almost at 0.5c wrt us? Let's call it galaxy B
You have to be vary careful because the light we see from such distant sources left them a long time ago. The universe has expanded and the Hubble Constant has changed its value since then.
A galaxy we see with a redshift of z=1.597 would have been receding at the speed of light at the time the light was emitted, it is now receding at 1.054c. It would have been 5.85 billion light years from us at that time and is now 15.18 billion light years away (the distance ratio is 1+z ~ 2.6). The light was emitted 9.739 billion years ago.
For z=0.685, the speeds are 0.5c then and 0.573c now, distances are 4.898 billion light years then and 8.253 billion light years now. The light was emitted 6.392 billion years ago.
You are trying to compare galaxies seen at completely different times so the question is at what time are you trying to calculate their relative separation rate?
The most distant known galaxy, GN-z11, has a redshift of z=11.09, we see it in light that was emitted 13.38 billion years ago, it was receding at 4.32c at that time and was 2.663 billion light years away then. It is now 32.2 billion light years away and is receding at 2.235c.
Likes Stephanus
Related to Hubble flow and velocity addition
1. What is Hubble flow?
Hubble flow refers to the outward expansion of the universe, first observed by astronomer Edwin Hubble in the 1920s. This expansion is caused by the continuous stretching of space itself.
2. What is the Hubble constant?
The Hubble constant is a measure of the rate at which the universe is expanding. It is denoted by the symbol H0 and has a value of approximately 70 km/s per megaparsec. This means that for every megaparsec (3.26 million light years) of distance, objects are moving away from us at a speed of 70 kilometers per second.
3. How does Hubble flow affect the velocity of objects in the universe?
Objects in the universe are carried along with the expansion of space, so their velocity is determined by both their own motion and the stretching of space due to Hubble flow. This is known as the velocity addition formula, which takes into account the relative velocities of the observer, the object, and the expansion of the universe.
4. How does Hubble flow affect the redshift of objects in the universe?
Hubble flow causes objects in the universe to have a redshift, meaning their light is shifted towards longer (redder) wavelengths. This is because the light is stretched as it travels through expanding space. The amount of redshift observed is directly proportional to the distance of the object.
5. What is the significance of Hubble flow in understanding the age of the universe?
Hubble flow is crucial in understanding the age of the universe as it provides evidence for the Big Bang theory, which suggests that the universe began as a single point and has been expanding ever since. By measuring the rate of expansion, scientists can estimate the age of the universe, which is currently believed to be around 13.8 billion years.
  • Cosmology
  • Cosmology
  • Cosmology
