Hubble parameter in terms of the scale factor
In summary: H_o^2}{H^2}## would be dropped.The factor of ##\frac{H_o^2}{H^2}## is dropped because it is conventional to do so and it makes the expression for the Hubble parameter shorter.
Figaro
103
From Introduction to Cosmology by Matt Roos, he wanted to derive the Hubble parameter in terms of the scale factor. From the Friedmann's equation,
##\frac{R'^2 + kc^2}{R^2} = \frac{8πG}{3}ρ##
The density parameter is ##~Ω(a) = \frac{8πG}{3H_o^2}ρ(a)~## and let ##~Ω_k = \frac{-kc^2}{H_o^2}##
So, ##~H(a)^2 = H_o^2 ( Ω_k a^{-2} + Ω(a) )~~## where ##Ω(a) = Ω_m(a) + Ω_r(a) + Ω_λ(a)##
m = matter, r = radiation, k = curvature, λ = cosmological constant
It is also known that the density parameter evolves as (for example, a matter dominated universe)
##~Ω_m(a) = Ω_m \frac{H_o^2}{H^2} a^{-3}##
The expression for the Hubble parameter in terms of the scale factor is,
##~H(a)^2 = H_o^2 ( Ω_m a^{-3} + Ω_r a^{-4} + Ω_k a^{-2} + Ω_λ ) ##
But how is that possible? If I substitute the density parameters in terms of how they evolve, there will be an extra factor of ##~ \frac{H_o^2}{H^2}~##. Any comments?
Space news on Phys.org
I think the problem here is that [itex]\Omega_m(a)[/itex] is quite different conceptually from [itex]\Omega_m[/itex]. The former is the density fraction over time, while the latter is the current density fraction.
The density of matter over time, for example, is given by:
[tex]\rho_m = {3H_0^2 \over 8\pi G}{\Omega_m \over a^3}[/tex]
You can think of the [itex]\Omega_m[/itex] in this equation as providing a sort of "initial condition" for the density parameter, which then evolves in accordance with the conservation of stress-energy (which gives the [itex]a^{-3}[/itex] scaling).
The density fraction over time ([itex]\Omega_m(a)[/itex]) compares that density over time to all of the other densities, providing an estimate of how relevant that particular component of the universe was to the expansion at any given point in time.
I must admit I also don't get it. Why is there the ##\frac{H_0^2}{H^2}## at all? Shouldn't it be just ##\Omega_m(a)=\Omega_ma^{-3}##? Aftetr all, if you add the ##1/H^2## the matter density goes down slower than ##a^{-3}##, which is what I understood was supposed to happen in a purely matter dominated universe?
That wouldn't give you the density fraction over time. It'd give you a dimensionless matter density over time.
But the current density in the book and other sources in the internet is given by
##\rho_m = {3H_0^2 \over 8\pi G}{\Omega_m}~##, so that ##Ω_m = \frac{ρ_m}{ρ_c}~## where ##ρ_c## is the critical density.
It is the relationship of ##~Ω_m(a)~## and ##~Ω_m~## that should involve the scaling, say, ##~a^{-3}~## in the case of matter dominated universe.
It is conventional (but confusing) to drop a subscript in order to avoid notational clutter, i.e., this is shorthand for
$$H(a)^2 = H_o^2 ( Ω_{m,0} a^{-3} + Ω_{r,0} a^{-4} + Ω_{k,0} a^{-2} + Ω_{λ,0} ).$$
See the text between equations (1.3.34) and (1.3.135) in Baumann's notes.
Yes, my question is the derivation Matt Roos did, I know that there should be a factor of ##\frac{H_o^2}{H^2}## in the evolution of the density parameter, but by plugging it in the corresponding equation to get
it wouldn't turn out that way, as in my post.
Sorry, I misunderstood. Maybe I still misunderstand, but ...
in a matter-dominated universe,
H_0^2 \left[ Ω_{m,0} a^{-3} + \Omega_{k,0} a^{-2} \right] = H_0^2 \left[ \frac{H^2}{H_0^2} \Omega_m+ \frac{H^2}{H_0^2} \Omega_k \right] = H_0^2 \left[ \frac{H^2}{H_0^2} \Omega_m+ \frac{H^2}{H_0^2} \left( 1 - \Omega_m \right) \right],
where the Omegas without zero subscripts are the varying Omegas.
No because the critical density also evolves. If you want to check: the matter density at CMB (last scattering, a=1/1090) was ~0.75. This agrees with
##~Ω_m(a) = Ω_m \frac{H_o^2}{H^2} a^{-3}##.
Figaro's substitution removes the ## a^{-3}## from the equation he has given for H(a), so it is not the same equation any more.
PS. George has it right above. ;)
Likes Bandersnatch
I think there might be a possible error in Roos's book? Can you take the ratio of the arbitrary density to the present critical density and define it to be the arbitrary density parameter? I think it should not be the case, I think it should be,
##~Ω(a) = \frac{8πG}{3H^2}ρ(a) = \frac{ρ(a)}{ρ_c}~## where ##~ρ_c~## is the arbitrary critical density
as opposed to
##~Ω(a) = \frac{8πG}{3H_o^2}ρ(a) = \frac{ρ(a)}{ρ_{c,o}}~## where ##~ρ_{c,o}~## is the present critical density
Interestingly, the reason why this is not given in the books is probably because the substitution, after cancelling the Ho's, just gives you: ##H(a) = H##.
Yes because the sum of the density parameters should be 1?
Yes, by definition. This is why ##\Omega_k## is there.
So how should I resolve the derivation? It really seems there is something wrong
In (4.13) ##Ω(a)## corresponds to the arbitrary density parameters which are related as I have stated, but there is a factor ##~\frac{H_o^2}{H^2}~## preventing me to get the correct expression.
how does this differ from what george jones offered?
Plug in for example, ##~Ω_m(a) = Ω_m\frac{H_o^2}{H^2} a^{-3}~## there will be an extra ##~\frac{H_o^2}{H^2}##.
Pardon my density, but, I'm not seeing how you arrive at that conclusion.
In a matter dominated universe, the energy density evolves as
##ρ_m(a) = ρ_m (\frac{a_o}{a})^3##
The density parameter is defined to be,
##Ω_m(a) = \frac{8πG}{3H^2}ρ_m(a)~## and ##~Ω_m = \frac{8πG}{3H_o^2}ρ_m~##
##Ω_m(a) = \frac{8πG}{3H^2}ρ_m(a) = \frac{8πG}{3H^2}ρ_m (\frac{a_o}{a})^3 = \frac{8πG}{3H^2} \frac{3H_o^2}{8πG} Ω_m (\frac{a_o}{a})^3##
Thus, ##~Ω_m(a) = Ω_m\frac{H_o^2}{H^2} a^{-3}~## where we set ##a_o = 1##
Yes, but then the ##a^{-3}## disappears from the equation for H(a). I think you are simply doing the substitution the 'wrong way around'. You have to plug in ##\Omega_m##, not ##\Omega_m(a)##.
No, in my post#14, equation 4.13 is given by
##H(a)^2 = H_o^2 (Ω_k a^{-2} + Ω(a) )~## where ##Ω_k = 1 - Ω_o##
Each evolves as
##Ω_m(a) = Ω_m\frac{H_o^2}{H^2} a^{-3}~~~~Ω_r(a) = Ω_r\frac{H_o^2}{H^2} a^{-4}~~~~Ω_λ(a) = Ω_λ\frac{H_o^2}{H^2} a^{0}##
So,
##H(a)^2 = H_o^2 (Ω_k a^{-2} + Ω_m\frac{H_o^2}{H^2} a^{-3} + Ω_r\frac{H_o^2}{H^2} a^{-4} + Ω_λ\frac{H_o^2}{H^2})##
There is the factor ##~\frac{H_o^2}{H^2}~## that should not be around to make it correct.
Unless Roos made a mistake which I just noticed right now. In my post#14, just above eq 4.13, he substituted
##\frac{8πG}{3}~## by ##~Ω(a) H_o^2~## but I think it should be ##~Ω(a) H^2~## since everything is arbitrary, not the present value (this is my question to George Jones in my post#10), if it is the case then eq 4.13 should be
##H(a)^2 = H_o^2 Ω_k a^{-2} + H^2 Ω(a)~## then by substituting the corresponding density parameters
##H^2## will cancel with ##\frac{H_o^2}{H^2}~## leaving ##~H_o^2~## which will correspond to the correct expression.
Yes, substituting (4.9) into (4.10) gives
$$\frac{8 \pi G}{3} \rho = \Omega H^2,$$
so it looks like Roos made a mistake (by including the zero subscript on the Hubble parameter just before (4.13)).
I see, so eq 4.13 is also incorrect because it should be
##(H_o^2 Ω_k a^{-2} + H^2 Ω(a) )^½##
Does anybody know of any errata for Introduction to Cosmology 3rd Edition by Matt Roos?
Related to Hubble parameter in terms of the scale factor
What is the Hubble parameter?
The Hubble parameter, denoted as H, is a measure of the rate at which the universe is expanding. It is defined as the ratio of the velocity of a galaxy due to the expansion of the universe to its distance from Earth.
What is the relationship between the Hubble parameter and the scale factor?
The Hubble parameter is directly related to the scale factor, denoted as a, which describes the changing size of the universe over time. The Hubble parameter can be expressed as H = (1/a) * da/dt, where da/dt is the rate of change of the scale factor with respect to time.
How does the Hubble parameter change with the expansion of the universe?
The Hubble parameter is not a constant value, but rather it changes as the universe expands. This is because the rate of expansion of the universe is not constant, but rather it has been accelerating since the Big Bang. Therefore, the Hubble parameter also increases with time.
What is the significance of the Hubble parameter in cosmology?
The Hubble parameter is a crucial quantity in cosmology as it helps us understand the expansion of the universe and the evolution of galaxies. It also allows us to estimate the age of the universe and the amount of matter and energy it contains.
How is the Hubble parameter measured?
The Hubble parameter can be measured using various techniques, such as the observation of the redshift of distant galaxies and the measurement of the cosmic microwave background radiation. These measurements can then be used to calculate the Hubble parameter and study the expansion of the universe.
  • Cosmology
  • Cosmology
  • Cosmology
