Hurricane wind blowing across a flat roof
A hurricane wind of 180 km/hr affects a flat roof measuring 7.8 m x 12 m, prompting a discussion on calculating pressure difference and force exerted. The initial calculations were incorrect due to improper unit usage and incomplete equations. After reevaluating, the pressure change was determined to be 1625 Pa. This value was then used to calculate the force on the roof, resulting in a force of 152,100 N. The final calculations confirmed the accuracy of the results.
xKalax
1.A hurricane wind blows across a 7.8 m x 12 m flat roof at a speed of 180 km/hr.
What is the pressure difference?
How much force is exerted on the roof?
2. Homework Equations
P= p_atmos + pgd
P=F/A
p = 101300Pa - (1.3)(9.8m/s^2)(93.6m^2)
p = 100107.5Pa
100107.5Pa = F/(93.6m^2)^2
F = 8.8 * 10^8 N
I know this is wrong, how do I go about solving this problem?
That's not the right equation. Rather, it's not the entire equation.
First of all, the numbers you used don't even turn out to have the right units. As in, d = 93.6 m^2 doesn't have the right units for d.
And think about it, the speed is given for a reason. Get the full equation, and plug in the values, and easily get the answer.
ok, I got the change in pressure to be 1625 Pa, which is correct.
I plug that into F = pA and get F = 1625Pa * 93.6m^2 = 152100, this seems too big.
I got it right, thank you!
15K
11K
20K
