Huygens Principle - how to explain this with classical language?
In summary, the conversation discusses Huygens' principle and how it relates to the wave function and wave front. The main idea is that every point on a wavefront can be considered as a source of secondary wavelets, and the second term in the equation represents this concept in classical language. The principle is proven for the wave equation in odd-dimensional space and can be further studied in the referenced source.
filip97
31
I was read this article(https://engineering.purdue.edu/wcchew/ece604f19/Lecture Notes/Lect31.pdf).
I was read this paper about Huygens' principle(https://engineering.purdue.edu/wcchew/ece604f19/Lecture Notes/Lect31.pdf)
Main idea of Huygens' principle is how wave function ##ψ(r)##
##r∈S=∂V##(S is wave front in time t) affect on shape of of wave function ##ψ(r′)## and shape of wave front ##S′=∂V′, r'∈S′## in time## t′,t<t′##
. We have:
##(∇^2+k^2)ψ(r)=0## (1)
##ψ(r′)=∮_{S}dS\hat{n}(G(r,r′)∇ψ(r)−ψ(r)∇G(r,r′)),r′∈V′##
,and
##ψ(r′)=0,r′∉V′##
where ##G(r,r′)##
is Green's function of (1)
First term ##\hat{n}G(r,r′)∇ψ(r)##
, can be interpeted how incident wave of point and unit source propagate in direction of surface normal of surface S′
Question is: How we can interpreted second term ##−ψ(r)∇G(r,r′)##
,respectevely how identified this therm as new source of spherical waves in point r, respectively how explain this with classical language ?
P.S. If ##−ψ(r)∇G(r,r′)## is wave of unit and point source in ##r'## is clear that amplitude in this point depend of ampliture of wave ##\psi(r)##
I think Huygens probably described it in classical language. Every point on a wavefront may be considered as a source of secondary wavelets. Whether it is proven, I don't know. I have never seen a finite wavefront which is not constrained in size by some object.
Huygen's principle works for the wave equation in odd-dimensional (configuration) space for ##d \geq 3##. You get it by calculating the Green's function of the D'Alembert operator and using Green's theorem in ##(1+d)## dimensions. For a thorough treatment, see
S. Hassani, Mathematical Physics, Springer Verlag, Cham,
Heidelberg, New York, Dordrecht, London, 2 ed. (2013).
https://dx.doi.org/10.1007/978-3-319-01195-0
Related to Huygens Principle - how to explain this with classical language?
1. What is Huygens Principle?
Huygens Principle, also known as the Huygens-Fresnel Principle, is a fundamental concept in classical wave optics. It states that every point on a wavefront can be considered as a source of secondary spherical waves, and the sum of these secondary waves determines the shape and propagation of the wavefront.
2. How does Huygens Principle explain wave propagation?
Huygens Principle explains wave propagation by breaking down a wavefront into smaller spherical wavelets, each of which acts as a source of new waves. These new waves interfere with each other, resulting in the overall propagation of the wavefront in a specific direction.
3. Can Huygens Principle be applied to all types of waves?
Yes, Huygens Principle can be applied to all types of waves, including electromagnetic waves, sound waves, and water waves. It is a universal principle that explains the behavior of waves in various mediums.
4. What is the significance of Huygens Principle in optics?
Huygens Principle is significant in optics because it provides a simple and intuitive explanation for the phenomena of diffraction and interference. It also forms the basis for many optical instruments, such as lenses and mirrors, which use the principle to manipulate and control the propagation of light.
5. How does Huygens Principle relate to the concept of superposition?
Huygens Principle is closely related to the concept of superposition, which states that when two or more waves meet, the resulting wave is the sum of the individual waves. Huygens Principle explains this phenomenon by showing how the secondary waves from each point on a wavefront combine to form the overall wave propagation.
  • Mechanics
  • Differential Equations
