Huygen’s Principle in 2 Dimensions
In summary, Huygen's principle is only valid in odd spatial dimensions, but it is often taught with the visual aid of 2 dimensional water waves. The reason for this is that in 2 dimensions, the Green's function for the d'Alembert operator does not have a delta function along the light cone, unlike in odd dimensions. This means that the diffracted wave pattern is not simply a superposition of spherical waves, but is instead "smeared" around the light cone. However, Huygen's principle does hold in 3 and higher odd dimensions.
FAS1998
50
I’ve seen posts similar to this one, but I’m still struggling to understand this concept.
Huygen’s principle is only valid with an odd number of spatial dimensions, yet it is often taught with the visual aid of 2 dimensional water waves.
So why doesn’t Huygen’s principle apply in 2 dimensions, and why does it apply in scenario shown with the water wave visuals.
The trick is to evaluate the retarded Green's function of the d'Alembert operator. So let
$$\Box G_n(x)=\delta^{(1+n)}(x), \quad G_n(x)=0 \quad \text{for} \quad t<0,$$
where ##x=(t,\vec{x})## is the (1+d)-dimensional spacetime vector of the Minkowski space with metric ##\eta_{\mu \nu}=\mathrm{diag}(1,-1,-1,\ldots,-1)##. We set the phase speed of the wave, ##c=1##. The d'Alembert operator is ##\eta^{\mu \nu} \partial_{\mu} \partial_{\nu} = \partial_t^2-\Delta##, where ##\Delta=\vec{\nabla}^2## is the ##n##-dimensional Laplace operator.
It's most easy to work with the socalled Mills representation, i.e.,
$$G_n(x)=\int_{\mathbb{R}^n} \frac{\mathrm{d}^n k}{(2 \pi)^n} \exp(\mathrm{i} \vec{x} \cdot \vec{x}) \tilde{G}_n(t,\vec{k}).$$
Plugging this "Fourier ansatz" into the equation of motion after some calculation one gets the harmonic-oscillator equation
$$(\partial_t^2+\vec{k}^2) \tilde{G}_n(t,\vec{k})=\delta(t).$$
Solving with the condition for the retarded propagator leading to the initial-value problem ##\tilde{G}_n(0^+,\vec{k})=0##, ##\partial_t \tilde{G}_n(0^+,\vec{k})=1## leads to
$$\tilde{G}_n(t,\vec{x}) = \frac{\Theta(t)}{||vec{k}|} \sin(|\vec{k}|t).$$
Now let's consider the cases ##n=3,2,1## (in that order). For ##n=3## we can evaluate the Fourier integral, using polar coordinates for ##\vec{k}##. Since ##G_n(t,\vec{x})## is rotation invariant, it depends only on ##r=|\vec{x}|##, i.e., we can choose the polar axis in direction of ##\vec{x}## without loss of generality. Then we get (with ##u=\cos \vartheta##)
$$G_3(t,\vec{x}) = \frac{\Theta(t)}{(2 \pi)^3} \int_0^{\infty} \mathrm{d} K \int_0^{2 \pi} \mathrm{d} \varphi \int_{-1}^1 \mathrm{d}u K \sin(K t) \exp(\mathrm{i} K r u).$$
Integration over ##\varphi## and ##u## yields
$$G_3(t,\vec{x}) = -\frac{\Theta(t)}{4 \pi^2 r} \int_{\mathbb{R}} \mathrm{d} K \sin(K r) \sin(K t),$$
where we have used the fact that the integrand is an even function in ##K## to extend the integration region for ##K## to the entire real axis. Resolving the sine function in terms of exp functions one gets ##\delta## distributions. Together with the unit-step function and using ##r>0## one finally gets the well-known result
$$G_3(t,\vec{x})=\frac{\Theta(t)}{4 \pi r} \delta(t-r).$$
Thus in ##3## spatial dimensions the Huygens principle is valid. This is seen by using the Green's function for solving the problem of diffraction for scalar waves on obstacles in the famous Kirchhoff approximate solution of the problem, which at the end boils down to the diffracted wave field given by the superposition of the spherical waves originating from each point in the openings of the diffractor (like a slit, double-slit, grating etc.).
Now from the Fourier integral of the Mills representation, it is easy to see that
$$G_{n-1}(t,\vec{x})=\int_{\mathbb{R}} \mathrm{d} x_n G_{n}(t,\vec{x}).$$
Using this for ##n=3##, we find
$$G_{2}(t,\vec{x})=\frac{\Theta(t)}{4 \pi} \int_{\mathbb{R}} \mathrm{d} x_3 \frac{\delta(t-r)}{r} = \frac{\Theta(t)}{2 \pi} \int_{-\infty}^{\infty} \mathrm{d} x_3 \delta (t^2-r^2).$$
Setting ##\rho^2=\vec{x}^2-x_3^2=x_1^2+x_2^2##, we get
$$G_{2}(t,\vec{x})=\frac{\Theta(t)}{2 \pi} \Theta(t^2-\rho^2) \int_{-\infty}^{\infty} \frac{1}{2|x_3|} [\delta(x_3-\sqrt{t^2-\rho^2}-\delta(x_3+\sqrt{t^2-\rho^2})] = \frac{\Theta(t-\rho)}{4 \pi \sqrt{t^2-\rho^2}}.$$
As you see, that's no ##\delta## distribution anymore. Of course, there's the singularity along the future light cone ##\rho=t## as it must be to get a Green's function, but it's not a ##\delta## distribution on the light cone. Thus the diffracted wave pattern is not simply a superposition of spherical waves going out from each point in the openings if the diffraction grating but it's somewhat "smeared around the light cone".
For ##n=1## one better uses the Mills-Fourier integral directly,
$$G_1(t,x)=\Theta(t) \int_{\mathbb{R}} \frac{\mathrm{d} k}{2 \pi} \frac{\sin(x t)}{k} \exp(\mathrm{i} k x).$$
To evaluate this integral, we note that ##\sin(k t)/k## for ##t>0## is the Fourier transform of
$$f(x)=\frac{1}{2} \Theta(-t<x<t)=\frac{1}{2} \Theta(t-|x|),$$
because
$$\int_{-t}^t \mathrm{d} x \exp(-\mathrm{i} k x)=\frac{2 \sin(k x)}{k}.$$
Thus we finally get
$$G_1(x)=\frac{1}{2} \Theta(t-|x|).$$
So in 1 dimension Huygens's principle doesn't hold either, but that's a special case.
If I remember right, the general case for odd dimensions ##n \in \{3,5,7,\ldots \}## Huygens's principle is valid. A proof is in
S. Hassani, Mathematical Physics, Springer Verlag, Cham, Heidelberg, New York,
Dordrecht, London, 2 ed. (2013).
https://dx.doi.org/10.1007/978-3-319-01195-0
Likes FAS1998 and weirdoguy
Related to Huygen’s Principle in 2 Dimensions
1. What is Huygen's Principle in 2 Dimensions?
Huygen's Principle in 2 Dimensions is a fundamental concept in physics that explains how waves propagate in two-dimensional space. It states that every point on a wavefront can be considered as a source of secondary wavelets that spread out in all directions at the same speed as the original wave. This principle helps us understand the behavior of light, sound, and other types of waves.
2. Who developed Huygen's Principle in 2 Dimensions?
Huygen's Principle was first proposed by Dutch physicist Christiaan Huygens in the 17th century. He used this principle to explain the behavior of light and its ability to travel in a straight line.
3. How does Huygen's Principle in 2 Dimensions apply to light?
In the context of light, Huygen's Principle in 2 Dimensions states that each point on a wavefront can be considered as a source of secondary spherical wavelets. These secondary wavelets combine to form a new wavefront, which continues to propagate in the same direction as the original wavefront. This principle helps us understand phenomena such as reflection, refraction, and diffraction of light.
4. What is the significance of Huygen's Principle in 2 Dimensions?
Huygen's Principle in 2 Dimensions is significant because it provides a simple and elegant explanation for the behavior of waves in two-dimensional space. It also serves as the basis for many important concepts in physics, such as the wave nature of light, interference, and diffraction.
5. Can Huygen's Principle in 2 Dimensions be applied to other types of waves?
Yes, Huygen's Principle in 2 Dimensions can be applied to other types of waves, such as sound waves and water waves. This principle helps us understand the behavior of these waves and how they interact with different mediums and obstacles.
