Huygens' theory, point on a wavefront, secondary wavelets
In summary: The secondary wavelets will interfere, but the amount of interference will depend on the shape of the beam. If the beam is Gaussian, the interference will add up and the beam will be gaussian. If the beam has sharp edges, the interference will add up and the beam will become the shape of a "sinc" function. Its a thought experiment, a beam of coherent light, does it interfere or not, with a source with no imperfections."A beam of coherent light" is not specific enough. Do you mean an infinite-width beam? A Gaussian beam? A higher mode beam? An ugly top-hat shaped beam? The ideal case is the Gaussian beam, which will produce a Gaussian
Rainbow
62
Huygens' theory says that every point on a wavefront serves as a source of secondary wavelet. Doesn't that imply that if we consider any coherent source of light, and intercept its waves on a screen, we'll get a diffraction pattern, as all those secondary wavelets will interfere among themselves?
every single point on the wavefront, as in there is an infinite amount of them on the wavefront
Of course Huygens' theory implies interference and diffraction, it wouldn't be much of a theory otherwise.
Claude.
Claude.
yes but does coherent light interfere when ther is no slit?
That's what I have asked.
They'll all interfere constructively and destructively, and the net effect exactly cancels as long as you account for ALL the points on the wavefront. If you only take part of the wavefront (like, if the light passes through a slit before reaching your screen), then the wavelets won't cancel and you'll see fringes.
There is no distinction to be made between diffraction and interference. They are both one and the same. Any wavefront will diffract regardless of the presence of a slit, or any other obstacle you might conceive. A plane wave is simply a special case because after summation of the secondary wavefronts, the wavefront does not change shape.
Claude.
Claude.
so then when you shine a laser onto a screen you get an interference pattern?
...because of the presence of edges in the resonanator cavity mirrors and output aperture, which limit the amount of wavefront available for "secondary wavelet" summation. The fringes are very faint.
its a thought experiment, a beam of coherent light, does it interfere or not, with a source with no imperfections.
"A beam of coherent light" is not specific enough. Do you mean an infinite-width beam? A Gaussian beam? A higher mode beam? An ugly top-hat shaped beam? The ideal case is the Gaussian beam, which will produce a Gaussian spot, and will do so because of interference rather than in spite of it.
the kinds of beams of light the hygun's theory is concerned with. what i mean is if you take the same coherent light that produces an interference pattern when traveling through a slit or double list, and removed the slits would it interfere? i think not
Think about what difference the slits make to the beam: the only relavent difference is the shape of the beam profile.
So if the beam profile is gaussian, the interference will add up to cause the beam profile to remain gaussian. If the beam profile has sharp edges, the interference will add up to cause the beam profile to become the shape of a "sinc" function.
Claude.
You mean all the secondary wavelets will interfere, but since there are an infinite number of these wavelets and they all interfere, the destructive interference at some will be overlapped with constructive interference of some other wavelets at that point ultimately giving a uniform intensity over a screen on which the light is intercepted. Right?
By "interfere", do you mean "produce light and dark fringes"? Ringing in the sense of fringes is caused by sharp edges, but light propagation (if it's done correctly) must include the possibility of multiple paths that add as waves - so in that sense it does always interfere, it just may not produce characteristic "diffraction" fringes.
Isn't ray theory strictly only valid at infinite frequency? Perhaps this isn't a problem in optics, but in global seismology (where frequencies are typically <10 Hz) a recently new finite-frequency (Dahlen, 2000) approach (used for tomography) has been necessary to account for such phenomenon as wavefront healing.
No, the fact there are an infinite number of wavelets is not special, any wavefront can be regarded as an infinite sum of wavelets (hence the need to use integrals), the wavefront itself needs to be spatially infinite in order for no change in the wavefront shape to occur.
Ice109; There is no distinction, mathematically or conceptually to be made between diffraction and interference. All beams (with a couple of artificial exceptions such as the aforementioned infinite plane wave) will diffract (remembering diffraction = interference), with the diffraction pattern being dependent on the original beam shape.
Claude.
Related to Huygens' theory, point on a wavefront, secondary wavelets
What is Huygens' theory?
Huygens' theory is a principle in physics that states that every point on a wavefront can be considered as a source of secondary wavelets, which spread out in all directions at the same speed as the original wave. This theory helps to explain the behavior of light and other waves.
What is a point on a wavefront?
A point on a wavefront is a specific location on a wave where all points are in the same phase. This means that the oscillations of the particles at that point occur at the same time and with the same amplitude.
What are secondary wavelets?
Secondary wavelets are small waves that spread out in all directions from a point on a wavefront. They are created when a wavefront encounters a barrier or an obstacle. According to Huygens' theory, the secondary wavelets combine to form a new wavefront.
How does Huygens' theory explain diffraction?
Huygens' theory explains diffraction as the result of secondary wavelets spreading out from the edges of an obstacle or aperture. These secondary wavelets interfere with each other, causing the wave to bend and diffract around the obstacle.
What is the significance of Huygens' theory?
Huygens' theory is significant because it provides a conceptual framework for understanding the behavior of waves. It helps to explain phenomena such as diffraction, reflection, and refraction, and has led to the development of many important theories and models in physics and other fields.
  • Other Physics Topics
