HW question w/ rotational kinetic energy
In summary: KE?Rethink which... no law of conservation or using KE?There is no obvious reason why KE conservation should not apply. It is the process of conversion of KE to angular speed that is unclear.There is no obvious reason why KE conservation should not apply. It is the process of conversion of KE to angular speed that is unclear.In summary, the problem involves a stationary horizontal platform with a radius of 1.6m and a moment of inertia of 660 kgm^2 that is free to rotate about its vertical axis. A 43 kg boy jumps on the rim of the platform with a tangential velocity of 2.2 m/s. The question is, what will be
Tony the Tutor14
: [/B]
A stationary horizontal platform is free to rotate about its vertical axis. The radius of the platform is R=1.6m and its moment of inertia is 660 kgm^2. A 43 kg boy jumps on the rim of the platform with the velocity 2.2 m/s tangential to the rim. What will be the angular speed of the platform with the boy?
: [/B]
K(rot) = (1/2)Iw^2,
v=wr, I=mr^2
: [/B]
I have been the solution of w=.197 rad/s.
I can’t figure out how to get the correct answer. I’m starting to wonder if the solution I’ve been given is incorrect. Any help would be appreciated. Thanks!
Please show your work (this is required according to forum rules). How have you tried to solve the problem?
Sorry. This is my first post. I’ve tried a few different ways to solve it.
Set KE of the boy = KE of the disk and solve for w.
I calculated the mass of the disk for use in the KE equation.
None of these have worked.
You should only apply conservation of work when there is good reason to suppose it is conserved. In this question, there is good reason to suppose it is not. What other conservation law(s) might apply?
I would just add that it is a good exercise to think about why there is good reason to suppose that kinetic energy is not conserved. It helps to think about what happens in the case of two freely moving masses that collide and stick together.
How about the conservation of angular momentum?
Could be. In what circumstances can you apply that? Do those circumstances occur here?
I don’t know. Right now, using the formulas for conservation of momentum and energy, I don’t see a path to calculate the correct answer. Any direction you can provide me would be very helpful. Out of the 15 questions in this problem set this is the only one I have not solved.
I don’t know
Angular momentum is (mostly) only meaningful in respect of a specified axis.
The condition for conservation of angular momentum of a system about a given axis is that no external force acting on the system has a torque about that axis.
In the present question, what axis wouldyou choose? Are there any external torques about that axis on the boy+platform system?
I would choose the axis of the platform and I believe the boy creates a torque about that axis.
The boy is part of the boy+platform system. The condition for applying the conservation law is that there are no external forces applying a torque about the axis.
Ok, so no law of conservation. Now I’m stuck on using KE to solve this problem.
I would appreciate some more assistance. I am not a student. I’m trying to help my son with his exam prep.
Rethink this conclusion! The boy is part of the system, so his influence is not an external one.
Rethink which conclusion?
The conclusion that no conservation laws apply.
It is important, before you begin to write equations for a problem, that you first define what comprises the "system" being analyzed. In that way you can determine whether any forces that act are internal or external.
In case you still do not get what gneill is telling you...
We are considering the system consisting of the boy and the platform. So any forces between the boy and the platform are internal to the system. These do not affect the total angular momentum of that system. What external horizontal force(s) might act on the system?
Gravity?
Gravity?
I specified horizontal.
Why doesn't the platform go skidding across the ground?
If the system consists of the boy and the platform, then there are no external forces acting on it. Therefore,
The problem states it is free to rotate about its vertical axis. I can only assume it is fixed about that axis.
No, there is a force.
Right. It does not go skidding across the ground because that axle exerts whatever horizontal force is necessary to prevent it.
So now we have identified the only external horizontal force acting on the system, we come to the last hurdle: does it exert a torque about your chosen axis?
No, because the axle is the axis of rotation, so there is no torque from it.
Right, so you can take angular momentum of the system to be conserved about that axis (but no other).
So, what is the angular momentum of that system just before the boy lands on the platform?
Zero, because the platform isn’t moving.
The system consists of the boy and the platform. The boy is moving.
I sincerely appreciate the effort you’ve put into help me, but your teaching method isn’t effective at this point. I would prefer if someone else could please help. Thank you for your time.
I wouldn't rely on that happening. Please persevere. We are getting there.
What is the boy's angular momentum about the axis just before he lands on the platform?
Related to HW question w/ rotational kinetic energy
1. What is rotational kinetic energy?
Rotational kinetic energy is the energy an object possesses due to its rotation around an axis. It depends on the object's mass, moment of inertia, and angular velocity.
2. How is rotational kinetic energy calculated?
The formula for calculating rotational kinetic energy is Erot = 1/2 * I * ω2, where Erot is the rotational kinetic energy, I is the moment of inertia, and ω is the angular velocity.
3. Is rotational kinetic energy the same as linear kinetic energy?
No, rotational kinetic energy and linear kinetic energy are different types of energy. Linear kinetic energy is related to the translational motion of an object, while rotational kinetic energy is related to the rotational motion of an object.
4. What is the difference between rotational kinetic energy and potential energy?
Rotational kinetic energy is the energy an object possesses due to its rotation, while potential energy is the energy an object possesses due to its position in a force field. They are two different types of energy and can be converted into each other.
5. How does rotational kinetic energy affect an object's motion?
Rotational kinetic energy affects an object's motion by increasing or decreasing its rotational speed. When there is a change in rotational kinetic energy, there is a corresponding change in angular velocity, which affects the object's rotational motion.
