accesskb
- 17
HW verification and question -- One-way concrete slab reinforcement problem
A rich developer has convinced you to design a suites hotel in a mixture of French Chateau and Colonial Revivalism.
The basic structure is to be comprised of a continuous oneway slab supported by concrete walls between rooms. The maximum spacing of the walls is to be 5m. The loading is to be as follows:
Live Load: 1.9 kPa
Superimposed dead load: 1.0 kPa
Dead Load: self-weight of slab – note that concrete is 23.5 kN/m3
1) Determine the minimum thickness (hmin) of the slab (round up to
the nearest 10mm) based on the thickness requirements provided
in the course notes. (
2) Determine the typical reinforcing required for both positive
bending moment (bottom bars) in the span and negative bending
moment (top bars) over the supports. For a continuous system,
the positive moment is Mf=wfL2/16 while the negative moment
over the support is Mf=wfL2/11. The minimum bar size to be used
is 10M for bottom bars and 15M for top bars. The maximum
spacing of reinforcing is 500mm. Cover is to be taken as 20mm.
f’c=30MPa.
negative moment
1) Minimum thickness of the slab (one-way continuous) = L/24 = 5000 mm / 24 = 210mm
(derived using the following equation from course handout)
(Clause 9.8.2.1 of CSA A23.3 provides minimum thicknesses for one-way construction that are useful for preliminary sizing of one-way systems in order to estimate self-weight for design purposes)
(Solid one-way slabs)
simply supported = L/20
One end continuous = L/24 <---------------------- I used this one.
Both ends continuous = L/28
cantilever = L/10
(Beams or ribbed one-way slabs)
simply supported = L/16
One end continuous = L/18
Both ends continuous = L/21
cantilever = L/8
2) see attached images.
page 1 -- http://farm4.static.flickr.com/3643/3347943836_96b598f895_b.jpg
page 2 -- http://farm4.static.flickr.com/3448/3347941934_ff9265f7c4_b.jpg
page 3 -- http://farm4.static.flickr.com/3643/3347943836_96b598f895_b.jpg
Live Load: 1.9 kPa
f’c=30MPa.
negative moment
cantilever = L/10
cantilever = L/8
