Hybridisation of SO3
The discussion centers on the molecular structure of sulfur trioxide (SO3) and the bonding characteristics of sulfur. It highlights that sulfur in SO3 is sp2 hybridized, allowing for the formation of three double bonds with oxygen atoms, resulting in a total of six electrons from sulfur and twelve electrons in the entire molecule. However, there is a contention regarding the concept of an "expanded octet structure" for main group elements, which has been disproven, suggesting that sulfur can only form one double bond that resonates among the oxygen atoms. This raises questions about the electron configuration and bonding capabilities of sulfur in SO3, particularly in relation to the availability of unhybridized p-orbitals for pi bonding.
hellohellohello
Since SO3 has an expanded octet structure, the central S should form three double bonds with O, meaning S forms 3 pi bonds in total. However, after hybridisation of S, there are less than three unpaired electrons in unhybridised p-orbitals of S. How can S form 3 pi bonds when there aren’t enough electrons from unhybridised p-orbitals? Thanks.
Likes dextercioby
Chemistry news on Phys.org
SO3 does contain three double bonds with O. Sulfur is SO3 is sp2 hybridized. I count six electrons? And of course two for each oxygen atom for a total of 12 electrons in the system.
Did I misunderstand your question?
There is no such thing as "expanded octet structure" in main group element chemistry. This has long been disproven. So at most one double bond, which may resonate between the different O-atoms.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
