Hydrated copper (II) sulfate mass calculation
In summary, to calculate the percent by mass of water in a sample of hydrated copper (II) sulfate, we need to use the formula %by mass = mass of part/mass of whole. In this conversation, we also discussed the balanced equation for the reaction, the possible observation when heating a hydrated ionic compound, the effect of incomplete conversion on the molecular formula, and the effect on the calculated percent by mass of water in the compound.
Aya
46
calculate the precent by mass of water in a sample of hydrated copper (II) sulfate.
mass of beaker-165.3g
mass of beaker with bluestone-173.9g
mass of dehydrated bluestone-170.7g
Would this be a ballanced equation for this reaction?
CuSO4•5H2O+ heat= CuSO4+5H2O
so would you do this
%by mass=mass of part/mass of whole
=90.1g/249.7g/molx100
= 36%
is this correct?
No. But it is so wrong I have no idea how to help you :(
Start calculating mass of the copper sulfate before roasting and after roasting.
lol, its ok i figured that part out
i have different questions now
Suppose you heated a sample of hydrated ionic compound in a test tube. What might you expect to see inside the test tube, near the mount of the test tube? Explain
You would see water droplets and steam. This is because a hydrate indicates the presents of water, when you heat a hydrated ionic compound the water will separate from the compound, and you will see some of the water collecting near the mount of the test tube. The steam could be a result of the water, or the compound evaporating
would that be right?
Suppose that you did not completely convert the hydrate to the anhydrous compound. Explain how this would affect the molecular formula you determined?
you would get more molecules of water?
Ionic compounds generally are nonvolatile solids and have high boiling points. Stick to the water answer.
No, think about what the question is saying here. Some water molecules are leaving the compound, just not all of them. When all the water has gone from the compound, then you will have the anhydrous product.
^ok thanks
7. Suppose that you did not completely convert the hydrate to the anhydrous compound. Explain how this would affect the calculated percent by mass of water in the compound?
If the hydrate was not completely converted to the anhydrous compound, the mass of anhydrous Cu(II)SO4 would increase because it would not be pure anhydrous Cu(II)SO4, instead it would be CuSO4•5H2O, in other words you would be weighing the compound plus water. In turn, this would change the mass of H2O, making to higher (for example instead of 3.2g it might be 4.2g.) the results of the percent composition calculation would also change to a higher number, for example %= (4.2/8.6)100 would equal 48.8% of water, compared to 37.2% of water, which is what we got by completely convert the hydrate to the anhydrous compound.
Related to Hydrated copper (II) sulfate mass calculation
1. How is the hydrated copper (II) sulfate formula written?
The formula for hydrated copper (II) sulfate is CuSO4 · xH2O, where x represents the number of water molecules attached to each copper (II) sulfate molecule.
2. How do you calculate the molar mass of hydrated copper (II) sulfate?
To calculate the molar mass of hydrated copper (II) sulfate, you need to first determine the molar mass of each element present in the compound (copper, sulfur, oxygen, and hydrogen) and then add them together. For example, the molar mass of CuSO4 is 159.61 g/mol, and the molar mass of H2O is 18.02 g/mol. If x = 5, then the molar mass of hydrated copper (II) sulfate would be 249.67 g/mol (159.61 + 5*18.02).
3. What is the percentage of water in hydrated copper (II) sulfate?
The percentage of water in hydrated copper (II) sulfate is dependent on the value of x in the compound's formula. For example, if x = 5, then the percentage of water would be 5/6 or 83.33% (since there are 6 total molecules in the compound).
4. How do you calculate the mass of hydrated copper (II) sulfate from a given number of moles?
To calculate the mass of hydrated copper (II) sulfate from a given number of moles, you can use the formula: mass = number of moles * molar mass. For instance, if you have 0.5 moles of hydrated copper (II) sulfate with x = 5, the mass would be 0.5 * 249.67 g/mol = 124.84 grams.
5. Why is it important to consider the hydration of copper (II) sulfate?
The hydration of copper (II) sulfate is important because it affects the physical and chemical properties of the compound. For example, hydrated copper (II) sulfate is a blue solid, while anhydrous copper (II) sulfate is a white powder. Additionally, the addition or removal of water molecules can change the compound's reactivity and solubility in water.
50K
108K
15K
