Hydraulic jack - Pascal's principle
In summary, the conversation discusses the concept of force and pressure in relation to a hydraulic system. The calculations show that a 500N force is not enough to lift a 500kg mass, as it requires a force of 543N. The distance depressed on the small piston side is 1mm, with a ratio of 9:1 between the two areas.
DevonZA
181
P1=P2
P=F/A
F=PA
F1/A1=F2/A2
F2 = F1(A2/A1)
F2 = W(A2/A1)
W=mg
W=F*d
A1= pi/4 * d2 = pi/4 * (0.15)2 = 0.0177m2
A2 = pi/4 * d2 = pi/4 * (0.05)2 = 0.00196m2
P1=P2
P=F/A
F=PA
F1/A1=F2/A2
F2 = F1(A2/A1)
F2 = W(A2/A1)
W=mg
= 500 * 9.81
= 4905N
F2 = W(A2/A1)
= 4905 (0.00196/0.0177)
= 543N
1.1) Therefore the force of 500N cannot lift the 500kg mass because 543N is required to do so.
1.2) W=F*d
= 543 x 0.01
= 5.43J
W= F*d
5.43 = 4905 x d
d = 5.43/4905
d = 0.001m
= 1mm is the distance depressed.
I am confused. What is your question for us?
Your part 1 is correct. I am not sure what they want in 2nd part. Are they assuming that now you do have sufficient force and you push down a distance of 10 cm?
I only want to confirm that my answers are correct.
In 1.2 I believe they want to know the distance moved on the side of the mass when 10mm pushed down on the small piston side
What is the ratio of the two areas?
DevonZA said:
3:1
That is the ratio of diameters. What about the areas?
Ratio = 0.0177/0.00196
= 9
Therefore ratio is 9:1
Related to Hydraulic jack - Pascal's principle
What is a hydraulic jack?
A hydraulic jack is a device used to lift heavy objects by applying a small force through the use of pressurized fluid, typically oil. It works on the principle of Pascal's law, which states that pressure applied to a confined fluid will be transmitted equally in all directions.
How does a hydraulic jack work?
A hydraulic jack consists of two connected cylinders – a small one and a larger one. The larger cylinder is connected to a reservoir of oil while the smaller cylinder is connected to the object being lifted. When force is applied to the small cylinder, it exerts pressure on the oil, causing it to flow into the larger cylinder and lift the object.
What is Pascal's principle?
Pascal's principle, also known as the principle of transmission of fluid-pressure, states that pressure applied to a confined fluid will be transmitted equally in all directions. This means that any change in pressure at one point in a fluid will be felt at all other points in the fluid.
What are the advantages of using a hydraulic jack?
One of the main advantages of using a hydraulic jack is its ability to lift heavy objects with relatively little force. It also allows for a smooth and controlled lifting motion, making it a safer option compared to other lifting methods. Additionally, because it uses a fluid, it can be used in a variety of environments, including underwater.
What are some common uses for hydraulic jacks?
Hydraulic jacks are commonly used in automotive and industrial settings for tasks such as lifting cars, trucks, and heavy machinery. They are also used in construction for lifting and leveling structures. In addition, they are used in aircraft maintenance, shipbuilding, and even in medical equipment such as hospital beds and dental chairs.
